Fri, Nov 22, 1:50 PM CST
Subject: Wet&Wounded with animations ?
sasqwach ( ) posted Sun, 13 June 2010 at 7:21 AM · edited Fri, 22 November 2024 at 1:17 PM
Anyone out there using Wet&Wounded ?
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=67705
It’s a truly great product but I was I was wondering if anyone else has run into the same issue I’m having with it ?
I've noticed when I apply the texture maps to single image renders all is fine; but when working with animations, the pattern of wounding seems to randomize or become inconsistent.
 For example here’s mike 4 with Bloodied applied to him in a 30 frame animation
Frame 1
Frame 30
See around the arms, hands and wrists ? As you see the original areas with wounded shading have moved or disappeared. Although some parts of the wounding appear consistent, some parts just disappear. When actually making a movie file I get a kind of “Squirming” look, check out the avi here
 http://www.sasqwach.com/render/animation.avi
 Is there any way I can apply the shader that it would remain consistent through all frames ? I tried experimenting in the materials tab of poser and locking shaders to “animated” but still seems to fluctuate through frames.
 Really hope someone can help me shed a little light on this,looking forward to using it in my animations !
Much obliged
IsaoShi ( ) posted Sun, 13 June 2010 at 7:46 AM
Make sure that the image map nodes are not using Global_Coordinates. That could be the issue.
TrekkieGrrrl ( ) posted Sun, 13 June 2010 at 7:52 AM
 I don't know the product, but some nodes have a "coordinates" checkbox. If one is present, try checking it. I think it's called Global Coordinates.
If you post the node setup it's easier for all the Mat-gurus (I'm SO not one of them!)  to help you with exactly WHAT you should change :)
Ghostofmacbeth ( ) posted Sun, 13 June 2010 at 10:46 AM
Another way to do it is to control with with an image map.
sasqwach ( ) posted Mon, 14 June 2010 at 12:59 AM
THANKS !
Switching off the Global Coordinates for each of the skin maps (Torso, legs, etc) worked beautifully! (or disgustingly)
Animating smoothly now
Many Thanks all !
sasqwach ( ) posted Tue, 15 June 2010 at 4:55 AM · edited Tue, 15 June 2010 at 4:56 AM
For anyone else having same issue;
After applying the skin texture, go to Materials Tab, select each skin material ie SkinTorso, SkinHead, click advanced tab.
Amongst the nodes you will see one titled SVClouds, open the parameters of that box, and check global_coordinates to OFF, move onto next skin.
Little bit time consuming but keeps the pattern consistent through all frames.
