Thu, Nov 14, 8:23 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: Using products made for Daz Studio in Poser?
dlm4001 ( ) posted Thu, 24 June 2010 at 7:10 AM · edited Thu, 14 November 2024 at 8:18 PM
I purchased EveryDay Lingerie for the V4 Bodysuit from the Daz Site.  The promotion page said that it was 'optimized for DS".  I did not read that to mean DS only.
I would like to use the extension for the body suit in Poser, and I installed it to a temp directory.  The files under People/V4 are of type '.ds' and the textures are under the runtime/textures.
Is there a way to import or convert products like this to work with Poser?
Thanks for any help,
Dennis
pjz99 ( ) posted Thu, 24 June 2010 at 7:22 AM · edited Thu, 24 June 2010 at 7:24 AM
There is a free addon for D|S called "Poser Format Exporter", you can probably export the item with that and then be able to load it in Poser.
http://www.daz3d.com/i/shop/itemdetails/?item=8040
If that doesn't work I suggest you return it and just keep a careful eye on that kind of thing in the future.
edit: hmmm that does not handle materials.  If that item consists of transparency maps, as it sounds, maybe you can set these up yourself by hand in Poser's Materials room.
My Freebies
hborre ( ) posted Thu, 24 June 2010 at 7:50 AM
I just looked at the product ID number and there is a ds designation present which means that it is a DS product only.  If you want it to work in Poser, you will need to manually reconstruct the maps in the material room.  Otherwise, as pjz99 suggested, As for a credit or refund.
dlm4001 ( ) posted Thu, 24 June 2010 at 8:19 AM
Thanks for the information, both if you.  I am not new to the material room, so I will apply the textures and transparencies that way.    If I get it to work, I will post back here.
I agree that this was my fault for not paying attention.
