Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
I've had the same problem with some figures, especially the Millenium ones like Victoria 3 and Michael 3. I never found an explanation or a real solution, but I have an annoying workaround:
I rename all the 'Twist' parameters to something else, and make my scripts use that new parameter name (I use 'Twost'). What's annoying about this is that I can't do the renaming from a Python script. I have to go in and manually rename every Twist parameter. I now keep pre-Twosted figures in my library.
I am trying to create a script that randomly put values in bend,twist,side-side. It works except for one slight problem, Twist doesn't seem to want to work. I am currently writing it as:
scene = poser.Scene()
figure = scene.CurrentFigure()
p1 = figure.Actor("Chest").Parameter("Twist").SetValue(2)
I tried this in the PoserPython Shell. If I did bend or side-side, it works. For twisting, it doesn't. Am I writing this wrong?
