Fri, Nov 22, 11:35 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Surface Replicator
GreenHawke ( ) posted Sun, 27 June 2010 at 3:54 PM · edited Thu, 01 August 2024 at 5:57 AM
Can anyone point out a good tutorial on the surface replicator?  I have watched a TON of videos on Carrara, but can't recall any on that particular subject.  I need one for free, too.  "Broke the bank" getting Carrara and a few other DAZ goodies...  :biggrin:
Oh...   It's Carrara 8 Pro...
Thanks much!
The most exciting phrase to hear in science, the one that heralds new discoveries, is not 'Eureka!' (I found it!) but 'That's funny ...'
Isaac Asimov (1920 - 1992)
GKDantas ( ) posted Sun, 27 June 2010 at 4:12 PM
You can look here:
http://carraralounge.com/index.php?topic=316.0
and here too
http://carraralounge.com/index.php?topic=400.0
Follow me at euQfiz Digital
animajikgraphics ( ) posted Sun, 27 June 2010 at 4:12 PM
Here's one:  Tutorial on Surface Replicator.
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
GreenHawke ( ) posted Sun, 27 June 2010 at 5:12 PM
 Thanks very much for those links!  They were VERY helpful....
GreenHawke ( ) posted Sun, 27 June 2010 at 7:26 PM
 Wow...   I sure hope some one's still watching this thread!
I managed to replicate a field (plane) of grass clumps from a single clump (object) and they are slightly "randomized" well.  My problems how to get them to conform to the terrain. I tried using collision detection, but, as you know, that didn't work...
 If this is a big learning curve item, please feel free to pass it by.  Just trying to avoid buying a set of tut disks for a couple more weeks...
Thanks a whole lot!
Kevin
GKDantas ( ) posted Sun, 27 June 2010 at 7:39 PM
To replicate in a surface you need to use Surface Replicator not only replicator.
GreenHawke ( ) posted Sun, 27 June 2010 at 7:48 PM · edited Sun, 27 June 2010 at 7:49 PM
Quote - To replicate in a surface you need to use Surface Replicator not only replicator.
That is what I used.  I have a terrain on which I am attempting to make a grassy area.  I used a plane for the template of the area to cover.  All of the "clumps" are on that plane.  I assumed that by utilizing collision detection I could "land" them all on the terrain surface.
THANK YOU....
Kevin
GKDantas ( ) posted Sun, 27 June 2010 at 9:01 PM
Plane for template?? So they will rest in plane not in the terrain. Do it right in the terrain. The collision detection only work for small obects and not for replicators.
Hoofdcommissaris ( ) posted Mon, 28 June 2010 at 3:23 AM
Actually, the location of the hotpoint will determine their position on the terrain.
rexus ( ) posted Mon, 28 June 2010 at 4:49 AM
place the  hot point at the bottom of the object and assign the same z value to the surface replicator hot point. it should work
GKDantas ( ) posted Mon, 28 June 2010 at 5:23 AM
Yes, good point: hot point. To change it position use the CapsLock key.
GreenHawke ( ) posted Mon, 28 June 2010 at 6:17 PM
 Thanks!  I appreciate all the help!
 I'm not feeling QUITE so lost!  🆒
bwtr ( ) posted Mon, 28 June 2010 at 6:53 PM
A tree Surface Replicated on a landscape. Great fun. Brian
bwtr
