Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
You can export it as point-level animation, and some applications can import such, but be warned that disk space required for this kind of thing can be VERY large. Basically you export 1 OBJ file per frame. Here's a thread that discusses the mechanics:
http://forums.cgsociety.org/archive/index.php/t-444692.html
To me, one main attraction of DAZ Studio is its relatively new, integrated Decimator Plugin; it allows me to do Polygon Reduction on figures in a way that preserves animations, morphs, etc.; another workflow of mine is: Export .obj files from Poser for each keyframe of an animation; then do polygon reduction on these .obj files using standalone 3rd party polygon reducers; BUT: The polygon-reduced .obj files have very probably NOT the same vertex count and order; the DAZ Studio Decimator allows me to export polygon-reduced .obj files which have exactly the same vertex count and order ... That's why I'm so keen on importing Clothify Animation into DAZ Studio, too ... Maybe importing a series of Poser-exported .obj files could be a way to go ...
Quote - the DAZ Studio Decimator allows me to export polygon-reduced .obj files which have exactly the same vertex count and order...
This is impossible. I suppose you could remove face information, but polygon reduction methods don't do this (and it wouldn't be very helpful to do this anyway, because it would only make a hole in your model where faces are removed).
Attached Link: http://www.verlsnake.eu
I know that I can save an animation made by clothifying a prop to the .pz3 format; and it will be read back correctly into Poser; but unfortunately not into DAZ Studio 3; is there a way to export 'Clothify Animation' from Poser to other 3D apps ? Or can it only be exported via a series of keyframe files ?
