Vue F.A.Q (Last Updated: 2024 Sep 17 9:46 am)
You are right, it does not work. The solution I gave you only works with looped rotating objects like propellors.
The reason why it does not work for you is that the position of group BldgA is also animated. If it would not be animated, and you would set the master group to "Forbid Animation" you can move it freely around, any time.
Regrouping is no option, you will loose all animation within the new group.
The thing you can do is move a copy on the first frame of animation, note the X, Y values of the new position, go to the last frame of the animation of group BldgA, correct the XY value. As long as there are no intermediate keyframes for the position this should work. Else you have to correct them as well.
Tip: If you want to move the keyframes in time, open the keyframe editor, expand all the groups so you can see all keyframes, draw a rectangle around all keyframes to select them. Now you can move them in time.
Cheers, N
Well, Vue keeps surprising me!
If you do the trick with the dummy primitive and go to the last keyframe of the BldgA group, and then move the dummy, it works! And it does not matter if there are any intermediate keyframes.
Man, had I known this before it would have saved me a lot of trouble!
Cheers, N
hi all
i made a building animation inside vue...the building consists of many parts i arranged each of them inside groups...and those groups are inside the main group which was named "bldg01"...i animated the group's objects and it was hard..the animation is as shown in this link:
http://www.youtube.com/watch?v=sa4oYINR21E
now i want to make a copy of "bldg01" and want to move it beside "bldg01" to have 2 buildings beside eachothers, i copied "bldg01" and named it "bldg02" and moved it beside "bldg01" while i was in frame 0 , now when i run the animation.."bldg02" moves till it gets into the same position where "bldg01" is...how can i avoid this problem??
looking forward to hear from you...thanks in advance
