Sun, Feb 9, 11:25 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 11:05 am)
Subject: Need Help Decapitating M4 i Poser 7 with group tool
CStrauss ( ) posted Wed, 07 July 2010 at 6:36 PM · edited Wed, 05 February 2025 at 5:49 AM
lol sorry for the strange title but yes that is exactly what I am trying to do M4 owes me a lot of money and hasn't paid so I am going to cut off his head. (the one on his shoulders you pervs) lol.
Anyway I figured out if I go to the group tool I can click on his head and create a prop out it. and save it but the problem is his eyes and the back of his neck get left out. The question I have and been trying to figure out how can I add the additional areas such as eyes and part of the neck to be included when I make his head a prop for me to roll around my scene?
In most programs you can have an option of selecting mulitple items by holding ctrl or shift key but that didnt seem to work in poser lol so is there something else I am missing?
CStrauss ( ) posted Wed, 07 July 2010 at 6:41 PM
Okay lol found something in the documentation about the group tool has two modes poly mode and vertix mode and in the setup room your in vertex mode and pose room in poly mode so I switched to the setup room and got his head chopped off lol.
But if there are other ways to do this I like to know. Also I am going to texture M4 so it looks like his head is cut off with blood and parts hanging out lol not sure what I am doing so any suggestion about texturing this effect I am open too.
hborre ( ) posted Wed, 07 July 2010 at 6:51 PM
An easier way, select M4's head and export as a wavefront obj.  The next window will ask either single frame or multiple frame (default single frame), click ok.  The window after that is critical, it is the body hierarchy to select the parts you would like to export together.  Make certain that weld all parts is selected.
The other method, make M4 completely invisible using the hierarchy window, make your selections, then export as wavefront obj.
CStrauss ( ) posted Wed, 07 July 2010 at 7:01 PM
aaah have to keep that one in mind but I just realized to doing the way I figured out I can make a more jaggy edge with my selections to make it more of a rough cut, but your way would be good for a clean decapitation like from a very sharp sword :)
thanks for the info now I can do two versions :)
markschum ( ) posted Wed, 07 July 2010 at 11:52 PM
You must realize that the cut part will appear hollow. There was a decapitation prop that filled in the neck but I dont remember if it was m4 or m3. There was one in renderotica freetuff.
fishak ( ) posted Thu, 08 July 2010 at 3:40 AM · edited Thu, 08 July 2010 at 3:46 AM
I'm not sure about this, but I think if you export/import, there's no way to keep the morphs.
If you can afford the resources in your scene, you may find it easier to simply make the body (or head) invisible, and use two figures. One figure for the head, and another for the body if you need that.
If you make an image file that's totally black, you can use it as a transparency to make whatever section of the neck you want to be invisible. With the grouping tool, you can select the parts of the neck you don't want to see, and assign a material to that section. Than use the black image as a transparency for that material.
If you don't want to have such a big file, you can hack the cr2 file with “Poser File Editor” or similar to get rid of the extra parts you don't need. This rout is harder, but can save lots of resources.
hborre ( ) posted Thu, 08 July 2010 at 8:07 AM
Not true.  You can apply your morphs and export/import obj without losing them.  You can even export 2, using one as a morph target in a 3rd party modeling program for finishing touches, as long as vertices count remain consistent between the two.
fishak ( ) posted Fri, 09 July 2010 at 4:09 AM
Thanks, hborre, I didn't know that, and will have to play around with it. I'm sure I could find a way to use this method with some of my figures and save some resources.
