Thu, Sep 19, 8:11 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 6:38 pm)
Subject: M3 and poserpro
darquevision ( ) posted Thu, 08 July 2010 at 3:53 AM · edited Thu, 19 September 2024 at 7:54 PM
i have recently had trouble using m3 in poserpro
for some reason any injection i use, everything is fine except his right shoulder down to hands. seems that part of him the injection doesnt work and i have tried to manually fix it but nothing.
i have reinstalled him and his body morphs but the problem remains.
any thoughts?
thanx in advance
darquevision ( ) posted Thu, 08 July 2010 at 4:01 AM
here is an example
infinity10 ( ) posted Thu, 08 July 2010 at 4:24 AM
Not just a PoserPro issue.  Happens in Poser 6, 7, and 8 if you don't add the fix.  M3 requires an update fix to work correctly.  Please obtain the fix from DAZ3D.
Eternal Hobbyist
darquevision ( ) posted Thu, 08 July 2010 at 5:31 AM
what is the exact file name of the fix?- i have been reinstalling and i should have it- however last time i used m3 was in poser5
is daz's fix free?
do you have a link for it?
thank you?
Dizzi ( ) posted Thu, 08 July 2010 at 5:38 AM
Reset the download for the M3 files in your DAZ account, redownload, reinstall.
darquevision ( ) posted Thu, 08 July 2010 at 5:40 AM
i got m3 ages ago- many years ago will they stil be there?
wrpspeed ( ) posted Thu, 08 July 2010 at 6:24 AM
yes they will.  just go to your purchases in your account and
reset on the m3 downloads, base figure and morphs.
takes about 10 min to reset the you can download them
darquevision ( ) posted Thu, 08 July 2010 at 6:59 AM
ok but now that i am thinking they were not purchased by me- if was a gift so i need to see if the sender still has this old info
thank you all for your help
hborre ( ) posted Thu, 08 July 2010 at 7:11 AM · edited Thu, 08 July 2010 at 7:12 AM
The main problem is with the body morph pack.  A corrupted version was circulated around ages ago, and although a Michael 3 service release is available, it does not correct the problem.  The M3 SR can be found here:
http://www.daz3d.com/i/support/downloads?product=m3&_m=d
Also notice, it is not only his left shoulder, but the left leg too that suffers from the applied morph.
darquevision ( ) posted Thu, 08 July 2010 at 7:51 AM
yes hborre you are correct- i got so annoyed with the shoulder that i did not even notice the leg  you are a great help as always(not to say the rest were not)
thank you
darquevision ( ) posted Thu, 08 July 2010 at 8:07 AM
hmmmmmmmmm i installed the link and used that as the base yet the same problem occurs the only why i have been able to combat it is to a long roundabout way (which if i am doing my own work is fine but if i am doing some quick thing is taxing)
darquevision ( ) posted Thu, 08 July 2010 at 8:10 AM
it seems so counter productive to create a new ver. of the base proggie that can not handle the older vers of the main models- in most cases as far as adobe and many others the later vers of the main software can handle the older esp. if it is a staple
sorry- i am a little annoyed
WandW ( ) posted Thu, 08 July 2010 at 7:15 PM
Quote - hmmmmmmmmm i installed the link and used that as the base yet the same problem occurs
He said that although there was a service release for the base figure, it didn't fix the morph issue; the fix is to get the current version of the morphs...
darquevision ( ) posted Thu, 08 July 2010 at 9:58 PM
ummmmm ty for the recap- but no offense i understood it
seems i will just do what i have been- using brom as the bases and tweeking from there
