Blender F.A.Q (Last Updated: 2025 Feb 16 5:25 pm)
I think the only solution as far as pre 2.50 versions are concerned is to stretch the window over both screens and make a split to coincide, then arrange the panel on one side or the other as desired.
According to the 2.50 info, it will have "tear off" and/or multiple window modes which should make life a lot easier.
Quote - I think the only solution as far as pre 2.50 versions are concerned is to stretch the window over both screens and make a split to coincide, then arrange the panel on one side or the other as desired.
This way works well enough but bear in mind that after shutting down and restarting (Blender that is), you have to 'stretch' it across both screens again. It doesn't remember there's two screens to cover.
Hello everyone.
I have just recently got my system set up with a dual monitor setup using a 1024/768 and a 1920/1080. What I want to do is use the larger monitor for the modelling side and the smaller one to hold all the buttons etc. Can anyone offer me a bit of advice regarding how to go about setting things up. I am in the process of using blender 2.49 and slowy getting my head around 2.5
Any help would be greatly appreciated.
Ian...
