Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 04 8:39 am)
If they are props, you'll need to parent them to M4's head before they will take MAT poses. Unparented props won't take MATs.
The item is just a texture and a mat-pose, which I assume has a shader in it, since the texture isn't black but the promo image shows black eyes. The comments under the freebie indicate others have been unable to load the texture either.
You don't need this to make eyes black. Go into iris and eyewhite materials and set them to black.
You can't screen cap something that won't load.
I just tried to load it - won't do anything to V4 or M4. No change. Nothing to see.
The mat-pose file is obviously messed up.
Yeah, there's nothing to show unfortunately.
Quote - You don't need this to make eyes black. Go into iris and eyewhite materials and set them to black.
Thanks. I'll give that a try, but...I'm assuming just setting them to black won't give the same results as what's shown on that preview image, all shiny and glossy with reflections. There must be other tweaks and settings applied to them...
What a bummer. I was hoping it was just me doing something wrong...I never even thought to look at the comments from others on the download page.
"You don't know what we can see
Why don't you tell your dreams to me
Fantasy will set you free." - Steppenwolf
It is a problem with the pz2 file, but easy to fix. :)
Open the file in a text editor, and at the top you'll see this section at the very top:
version
number 7.2
}figure
Here is what it should look like:
version
number 6
figure
Simply place the cursor between the word figure and the bracket and press ENTER, save the file and it should now work. :)
Okay, I tried that (substituted 7.2 for 6) but it's still not working. Or do I need to remove some blank spaces so that it looks exactly like how you've got it posted here?
EDIT:
Oh, I also pressed enter between the bracket and figure, but still nothing...
This is what it looks like now, in Notepad:
I've attached my working version of the file, just save it to your folder and remove the .txt extension and it should work. :)
Thanks for that DreamerZ_Loft. I was clueless what to do about it.
This is a freebie available in the R'osity Freestuff section.
I'm trying to use it on M4 (he and V4 can share the same eye textures, yes?) but the textures won't apply. I've tried with his body selected, his head, and his eyeballs...and nothing happens. So, I tried manually loading them into the material room, but that was a dismal failure. I really have no clue which parts of the eye to load the textures to, what settings to use, etc.
Can anyone help, please?
