Sat, Feb 1, 1:37 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 12:52 pm)
Subject: Poser Pro
IronHorse61 ( ) posted Tue, 20 July 2010 at 3:43 PM · edited Sat, 01 February 2025 at 10:54 AM
Im new to Poser, I try to open a simple object (a person) I change position of arms and legs just a little. But when I save (as Collada) and import to VUE the skin of the object breaks on the places where i changed positions of bodyparts. ?? Why it does like this. It´s only minor changes..
JunkoH ( ) posted Tue, 20 July 2010 at 4:01 PM
What version of Poser Pro are you using?  And which version of Vue are you importing to?
IronHorse61 ( ) posted Wed, 21 July 2010 at 12:39 AM
I use Poser Pro 2010, and VUE 8
pjz99 ( ) posted Wed, 21 July 2010 at 12:55 AM
Doesn't Vue read native Poser files?  I don't think you need to export to Collada (if that even works).
My Freebies
IronHorse61 ( ) posted Wed, 21 July 2010 at 2:24 AM
Yes VUE "should" read Poser files, but there are some issue with VUE8, It does not work to import directly. There are many threads about this issue. If I leave the object untouched and Import to VUE (as collada) It looks fine. But immediately when I make some changes the skin cracks.
seachnasaigh ( ) posted Wed, 21 July 2010 at 11:35 AM · edited Wed, 21 July 2010 at 11:37 AM
I have Vue 8 Infinite (just learning! ^^).  I export dolls from Poser as OBJ (weld body parts together!) and import that into Vue, and scale it up by 2.5 - this method works.
I hadn't tried direct import from Poser since I was going to re-do the materials in Vue anyway.
estherau ( ) posted Wed, 21 July 2010 at 9:01 PM
 i use the python script collectsceneinentory which is in the utilities folder, then I choose a folder for this.  then i export poser scene as .obj to same folder, then i use vue to import the .obj and usually all the textures come in fine.  sometimes you need to decrease the shinyness after in the vue scene using materials editor.  the hair was the only thing i adjusted in this scene and vue loaded all the textures itself ie quick and easy love esther
MY ONLINE COMIC IS NOW LIVE
estherau ( ) posted Wed, 21 July 2010 at 9:02 PM
 oh when vue asks click allow vue scaling  then u don't need to resize anything
IronHorse61 ( ) posted Thu, 22 July 2010 at 12:36 AM
I tried to export as .obj. And that worked, just some nagging about texture file missing. But I think I will solve.
estherau ( ) posted Fri, 23 July 2010 at 6:45 AM
 i mostly don't get messages to locate texture fils - just automatically does it correctly
