Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Sep 17 7:30 pm)
Another glitch was discovered (recently?) in Poser. If one adds a poser prop (or maybe even an imported prop) to a scene, then increases a dimension (or maybe all dimensions) of the prop drastically (perhaps 500% or more), the shadow-map calculations are screwed up. The end result is that props, perhaps even those that were not resized in any way, will either cast no shadows, or they will do so in an unpredictable or unsatisfactory manner.
I have created some large props and noticed that to get a figure to cast a clear shadow, I have to turn off "cast shadows". great! I get a good shadow from the figure but the prop no longer casts shadows on itself ( ie columns on floors etc) Is this a weakness in Poser rendering or is there a way around it.
