Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 24 4:22 pm)
If you don't know what IDL is, then you didn't turn it on, so ignore the comment about GI. GI is Global Illumination. Poser 8 has one of hundreds of approaches to GI, which is IDL. Many methods of GI produce variability that isn't real and this is apparent in animations. Adom thought you were running into this.
So you changed to raytraced shadows - did that fix it or not. If not you must show us what the symptom is, not with words, but with pictures.
Long time to render?
You're going about this the wrong way then.
What frame number shows the flicker? What frame number does not?
Render just those two frames and show me.
For purposes of demonstrating shadow problems, you don't need a whole animation, you don't need full size, and you don't need high render settings. You should be able to render two frames of about 400 pixels wide in less than 30 seconds.
I have just completed animation /poser8 / James g2 /Talk designer/ 2 lights/head camera
and I have animated flickering shadows across the face any ideas?
