Sun, Nov 24, 6:38 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 24 4:22 pm)
Subject: Render Poser8 shadows move across face
saibabameuk ( ) posted Sun, 01 August 2010 at 10:05 AM · edited Sun, 24 November 2024 at 6:32 PM
 I have just completed  animation /poser8 / James g2 /Talk designer/ 2 lights/head camera
and I have animated flickering shadows across the face any ideas?
Adom ( ) posted Sun, 01 August 2010 at 10:34 AM
If you enabled GI then you won't get rid of "flickering shadows" effect - I had a thread about it - but cannot find it.
If not then try increasing shadow map size resolution or change shadows to ray traced - may help.
saibabameuk ( ) posted Sun, 01 August 2010 at 10:45 AM
 Thank you
Sorry new to this enabled GI ?
I have changed to ray trace .
bagginsbill ( ) posted Sun, 01 August 2010 at 10:51 AM
If you don't know what IDL is, then you didn't turn it on, so ignore the comment about GI. GI is Global Illumination. Poser 8 has one of hundreds of approaches to GI, which is IDL. Many methods of GI produce variability that isn't real and this is apparent in animations. Adom thought you were running into this.
So you changed to raytraced shadows - did that fix it or not. If not you must show us what the symptom is, not with words, but with pictures.
saibabameuk ( ) posted Sun, 01 August 2010 at 11:01 AM
 Well it will take time it is a long render , I am hoping that changing to ray trace will do the job.
Thanks again will start the rend
ice-boy ( ) posted Sun, 01 August 2010 at 11:03 AM
there is a shadow only render option. that way you can preview the shadows.
bagginsbill ( ) posted Sun, 01 August 2010 at 11:04 AM
Long time to render?
You're going about this the wrong way then.
What frame number shows the flicker? What frame number does not?
Render just those two frames and show me.
For purposes of demonstrating shadow problems, you don't need a whole animation, you don't need full size, and you don't need high render settings. You should be able to render two frames of about 400 pixels wide in less than 30 seconds.
saibabameuk ( ) posted Sun, 01 August 2010 at 11:13 AM
 AH!
Changing to Ray Trace has done the job.
Quite right , the problem is sorted no flickering shadows.
All the frames were showing  the flicker.
Thank You All
ice-boy ( ) posted Sun, 01 August 2010 at 11:27 AM
dont forget to add some blur to the shadows. 100% sharp shadows dont look nice.
saibabameuk ( ) posted Sun, 01 August 2010 at 11:40 AM
 Will do , lost my concentration , went off on a tangent looking at Mr Bagginsbill
Environment Sphere fascinating
