Tue, Feb 4, 7:14 AM CST
Subject: Background image not rendering
pappy411 ( ) posted Fri, 30 July 2010 at 7:48 PM · edited Sun, 26 January 2025 at 6:49 PM
Background image renders fine in still image but will not render in animation.
I remember a thread a long time ago on this topic but cannot locate it.
Pappy
TrekkieGrrrl ( ) posted Fri, 30 July 2010 at 8:12 PM
 Does whatever animation you render to preserve the alpha channel? Poser'¨s bacground images 8as the normal background) is treated like an alpha channel and will for instance come out as transparent when rendered as png... Possibly that's the reason?
pappy411 ( ) posted Fri, 30 July 2010 at 8:18 PM
I am rendering as .AVI in P7.
pappy411 ( ) posted Fri, 30 July 2010 at 8:19 PM
I am rendering as .AVI in P7, Uncompressed
Slowhands ( ) posted Sun, 01 August 2010 at 3:38 PM
I have Poser Pro2010 and having the same Problem. But I get a message AVI not compatable, something like that.
What i did was make a complete scene, animate it with 4 different Charatures plus a store with all it's items. First I hid all the charactures and just animated the background in Images, Then made them into a movie using Adobe Premiere CS4.
Then I tried to use that animated background while rendering them as Image files. but the backgound animation does not show up.
I've tried using after effects to drop out a blue screen, but didn't like the final results.
pappy411 ( ) posted Sun, 01 August 2010 at 5:18 PM
Got a fix from Smith Micro.
Delete: Poser.ini
LibraryPrefs.xml
Poser UI Prefsxxxxx.xml.
this doesn't delete anything already there and Poser will rebuild these files the next time you start the program.  It is supposed to fix a multitude of Poser problems and worh a try for whatever glitch you may run into.
It fixed my Stuck animation pallete and saves having to reinstall.
Pappy
Slowhands ( ) posted Sun, 01 August 2010 at 11:31 PM
Thanks, I'll get over there and see if they have another Update that I might be missing.
pappy411 ( ) posted Mon, 02 August 2010 at 7:51 AM
Quote - Got a fix from Smith Micro.
Delete: Poser.ini
LibraryPrefs.xml
Oooops!  I meant to put this on another thread "Animation Pallete stuck"...Sorry.
Pappy
