Fri, Nov 22, 9:45 AM CST
Subject: Sketchup Import a little confused in bryce 7.
MagnusGreel ( ) posted Fri, 30 July 2010 at 10:06 AM · edited Sun, 17 November 2024 at 3:36 PM
erm.. Sketchup uses Skp as it's native not DAE.... (it can export to DAE (Collada)) methinks Daz got a little confused there..
Airport security is a burden we must all shoulder. Do your part, and please grope yourself in advance.
Rosemaryr ( ) posted Fri, 30 July 2010 at 6:25 PM · edited Fri, 30 July 2010 at 6:27 PM
Quote - erm.. Sketchup uses Skp as it's native not DAE.... (it can export to DAE (Collada)) methinks Daz got a little confused there..
 I think they mean the SketchUp exported version of the .dae file format.  I've tested the Bryce import of the Collada .dae format vs. the SketchUp version (from the Import file list in Bryce). Bryce brings in the SketchUp version, but not Collada one.  And even for that, the material file doesn't seem to work quite right yet.  But it's a start!
RosemaryR
"This...this is magnificent!"
"Oh, yeah. Ooooo. Aaaaah. That's how it starts.
Then, later, there's ...running. And....screaming."
jartz ( ) posted Fri, 30 July 2010 at 8:25 PM
I was wondering the same thing too.  Has anyone tried to work with SketchUp models with Bryce 7 any?
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Rosemaryr ( ) posted Fri, 30 July 2010 at 10:30 PM
I've done some investigations.... best method I've come up with is getting the .obj export plugin from here:
http://onigiriburning.so.land.to/
Get the su2objmtl2.zip file and go to where you installed Sketchup and unzip it and place it inside "..GoogleGoogle SketchUp 7Tools" and you should be good to go. When you run Sketchup it will appear in the plugins menu.
There are some problems with some of the earlier SketchUp free models, but there's a discussion of ways and means in this thread over at DAZ.
http://forum.daz3d.com/viewtopic.php?t=141125&postdays=0&postorder=asc&start=0
Bryce 7 will import the 'SketchUp' version of the .dae file, but with no mats applied.  And the SketchUp .skp files isn't on B7's import list.
That's all I have so far.
RosemaryR
jartz ( ) posted Fri, 30 July 2010 at 10:42 PM
I noticed that still doing the beta.  The .dea Import doesn't record, I think, the material part for SketchUp.  I do mostly detailed building work with SU, and that's why I asked.
Thanks for the input.
artbyphil ( ) posted Sat, 31 July 2010 at 12:44 PM
I use sketchup with Bryce quite a lot, I find  just using .obj the best so far. On import you can select group by material which is good. Does using dae give any other advantages over this?
pumeco ( ) posted Mon, 02 August 2010 at 9:13 AM
I asked Hak about this during it's development because it was pretty obvious that what DAZ were doing would confuse people.
When he brought up the subject of working on the DAE import, I suggested that they go the full mile and evolve this importer into one that could also handle .skp (native SketchUp) files as well.  The formats are related, and this seemed to be an obvious thing to do due to the popularity of the free SketchUp.  Bryce would get a flood of new users if those users were able to render their SketchUp models inside Bryce.
The good news is that Hak liked the idea.  The bad news is that there's no way of knowing if or when it will be implemented.  Personally, I think it will appear sooner or later - but there's no guarantee.  DAZ would be shooting themselves in the foot to develop that DAE importer and to not extend it to support native SketchUp.
artbyphil ( ) posted Mon, 02 August 2010 at 9:27 AM
Thats good to hear, native sketchup support would be great, hope they  do go ahead with it at some point. And as you say I'm sure it would bring  lot of new users to Bryce if they can get it working well it would be the perfect companion to sketch up .
