Fri, Nov 22, 6:25 PM CST
Subject: Vanishing Bodyparts
Cybertenko ( ) posted Wed, 28 July 2010 at 4:34 PM · edited Fri, 22 November 2024 at 1:09 PM
Strange thing about making figures in poser. Everything is ok, i will make figure otu of props, set the joint and textures and resave it in figures folder. But when I try to reload the figure, some of bodyparts simply vanish. They are in list of body parts, all have mats and all are set to be visible, but they are gone. The even do not appear when you search for outlines of invisible parts. What is that? What causes this strange thing?
pjz99 ( ) posted Wed, 28 July 2010 at 4:50 PM
This is probably because the geometry of the missing parts is not referenced correctly or at all in the CR2.
My Freebies
Cybertenko ( ) posted Sun, 01 August 2010 at 5:05 PM
I thought the same, but it is not the cause. I ve checked cr2 and its ok - referencing to obj, which includes all body parts.
here is my workflow:
I loaded all props into p6 (p8 keep crashing during it)
I set the hierarchy in editor and make the figure - all body parts are on place.
I make new scene and load justly made figure form "new figure" folder (now figure has embeded geometry, since no obj was produced)
I resave the figure into any folder - this time it produced obj (in the same folder as cr2) and after I reload this figure - some (most of them) bodyparts are gone.
It getting me nervous. What is wrong?
pjz99 ( ) posted Sun, 01 August 2010 at 5:22 PM
I'm actually about to go to bed but I don't mind having a look when I get back up, if you want to mail me a copy of the CR2+OBJ files.  Check your PM.
My Freebies
Cybertenko ( ) posted Sun, 01 August 2010 at 5:33 PM
OK, I will do. Thank you. Sleep well. :-)
Dreamrunner ( ) posted Tue, 03 August 2010 at 3:08 AM
I have also seen this happen in Poser 7 on the male default character of the default Untitled screen that comes with Poser.  In it his hip is invisible.
pjz99 ( ) posted Tue, 03 August 2010 at 7:43 AM
I never got any message from you, did you solve it?
My Freebies
Adom ( ) posted Tue, 03 August 2010 at 7:54 AM
Quote - I have also seen this happen in Poser 7 on the male default character of the default Untitled screen that comes with Poser.  In it his hip is invisible.
Invisible hip actor is (was?) a common problem - it has nothing to do with Cybertenko's case.
Just reopen poser and hip will be back.
Cybertenko ( ) posted Tue, 03 August 2010 at 7:58 AM
yes that is true, hip problem is another case. sometimes is enough to reload the figure. In my case vanishing some body parts after creating and resaving.
