Thu, Feb 20, 2:45 PM CST
Forum Moderators: RedPhantom
Subject: Unexpected realism? How did this happen?
TrekkieGrrrl ( ) posted Tue, 03 August 2010 at 7:42 PM · edited Thu, 20 February 2025 at 2:45 PM
 I've been making an UFO for an upcoming freebie... And when I was making what I reckoned should be the promo pic/thumbnail.. something odd happened... It looks like poor Simon is bleeding.. and while I sorta like the effect.. I can't figure out where those blood-like stains comes from... As far as I can see there's no reason for anything red to appear in that shader...
Oh and the background is one of Ajax' great shaders too btw, so it's not really there, it's just a shader plugged into the Background Colour... so that shouldn't be able to bleed either... at least I think not.
Here's the pic:
And here's the shader setup for the beam. It's probably unnecessary complicated, I took an old one I'd made I think back in the Poser 5 days and tweaked it some more to make a nice beam-effect.
As it's obvious, there's only blues in the shader.. so what's the blood?!
LostinSpaceman ( ) posted Tue, 03 August 2010 at 7:48 PM
What color are the lights and atmosphere?
estherau ( ) posted Tue, 03 August 2010 at 7:48 PM
 tractor beam creating more than 16 G of pull maybe?
hehe I don't know but the pic looks good and your UFO looks great!
Love esther
MY ONLINE COMIC IS NOW LIVE
ockham ( ) posted Tue, 03 August 2010 at 7:52 PM
The red stuff appears to be visible only in front of the reddish ground, and appears
to be only on one side of the cone, much like a highlight.
Also, there is a brown-type shade in your Color Ramp, which might be
coming through for some input values?
How does the beam look in front of a plain white background?
My python page
My ShareCG freebies
LukeA ( ) posted Tue, 03 August 2010 at 7:59 PM
Is back face culling on or off on the cone?
LukeA
My latest novel
LostinSpaceman ( ) posted Tue, 03 August 2010 at 8:01 PM
Actually it's apparent higher up as well which is why I asked about lights and atmosphere. It looks more black above the ground than red though.
TrekkieGrrrl ( ) posted Tue, 03 August 2010 at 8:03 PM
 Steve: Lights are all shades of grey (turned down version of the standard Country lightset)
Ockham.. samt thing wihen rendered over white. Now I'm getting really curious L
TrekkieGrrrl ( ) posted Tue, 03 August 2010 at 8:06 PM
 Oh and I didn't use any atmosphere.. so whatever the default Poser atmosphere is..
Luke the cone is just a simple cone. UVmapped as a cylinder. It should be one sided, and have the normals facing outwards as far as I know... not sure if that was what you meant. I agree that you can see the "inside" of it since it's partially transparent, but OTOK.. shouldn't it be showing on the backfacing parts and not in front of Simon then?
I'll try a render without Simon and see...
TrekkieGrrrl ( ) posted Tue, 03 August 2010 at 8:09 PM
 Hm the "blood" is showing the same also without Simon...
bagginsbill ( ) posted Tue, 03 August 2010 at 8:21 PM · edited Tue, 03 August 2010 at 8:21 PM
The other side the normals are facing away. We are looking at the back of the prop. Diffuse reflection doesn't happen in that case. So the partial transparency is giving us just a darkened version of the background - which looks red.
Click the "Normals_Forward"  checkbox in the PoserSurface root node and it will go away.
(Note: When you get a new toy, you should look at all the properties you've never seen before and wonder what they do.) grin
ghonma ( ) posted Tue, 03 August 2010 at 8:34 PM
Your cyan color is getting inverted in some places. Red is invert of cyan in CG color (ie if R,G,B, is cyan, 1-R, 1-G, 1-B is red)
TrekkieGrrrl ( ) posted Tue, 03 August 2010 at 8:36 PM
 L BB.. I usually DO just that. That's how I learned to model and how to use Poser (and for that matter, how to use a computer in the first place - by pressing buttons and see what happens)
What puzzles me is.. I did a lot of test renders while I was tweaking the beam material (and yea it sorta sucks, but.. er..) and those reddish blobs never appeared then.. so why are they turning up NOW?
Rendering the thing now with Normals Forward checked.. lessee if it really does help ;)
If not, then I'm convinced the Beam accidentally caught a groundhog or something L
TrekkieGrrrl ( ) posted Tue, 03 August 2010 at 8:39 PM
The World Has Officially Come To An End! BB's suggestion didn't work O.o
Quote - Your cyan color is getting inverted in some places. Red is invert of cyan in CG color (ie if R,G,B, is cyan, 1-R, 1-G, 1-B is red)
Ooh that MAY be it? I am indeed rendering with GC on... Hmm...
Soooo... how do I fix that? Short of rendering without GC which I'd rather not.
TrekkieGrrrl ( ) posted Tue, 03 August 2010 at 8:40 PM
 (uhm... anyone up for a better "beam" shader than this?... anyone? Bueller? BB?)
bats eyelashes
Winterclaw ( ) posted Tue, 03 August 2010 at 10:09 PM
I was looking through your shader and have some questions and comments:
I noticed you've set transparency edge to 0 then plugged something into it.  So whatever effect you were hoping for isn't happening.
You also have specular as black then set it to 1.
I'm playing around with math functions 10, but the bottom node input isn't doing much for me.
In math functions 11 you've got a cos and something plugged into the bottom node input, but it's set to 0, is that doing anything?
On what you've labeled turbelence 2, try switching your bias and gain to .2 and .8 and see what happens.  When I switched those from .5 my primitive cylinder got a lot darker.
Anyways, I've rebuilt it the best I could and I'm getting some black areas, but no red.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
bagginsbill ( ) posted Tue, 03 August 2010 at 10:26 PM
Oops - my bad. I didn't read past the first couple posts. I should have noticed that you rendered it over white and still got red.
So yeah it's probably because you have a negative color somewhere.
Here's an alternative.
bagginsbill ( ) posted Tue, 03 August 2010 at 10:36 PM
I'd stick a spotlight in the cone as well, with a Clouds node with the same colors as the beam.
Looks like this.
ShawnDriscoll ( ) posted Wed, 04 August 2010 at 2:00 AM
Quote - As it's obvious, there's only blues in the shader.. so what's the blood?!
I see a slight red splotch in your material preview.  There may be some also in the black areas where it is harder to spot.
LostinSpaceman ( ) posted Wed, 04 August 2010 at 3:31 AM
Here's one I just whipped up from an old Glitter shader for fabrics. I added .95 transparency changed the Transparency falloff to .02 and changed the color of the specular node to yellow. Applied the material to a cone and to a second copy of Ralph scaled up to 101% and wallah! Star Trek Beams!
TrekkieGrrrl ( ) posted Wed, 04 August 2010 at 6:26 AM
 Aaah  I'll experiment with other beams when I get home from work in a couple of hours :)
And BB I had thought of putting a spotlight there. I wonder if that can be saved along with the ufo and "turned on" when the beam is extracted (since the beam is morphable.. I like things that "do" something L)
As I said.. Experiment time. Soon :)
TrekkieGrrrl ( ) posted Wed, 04 August 2010 at 7:57 PM
Well.. I think I managed to make a better "beam" shader, mostly based on BB's suggestion :)
So the UFO is now finished and available for free. It's on my own site now and pending in Free Stuff here :)
Hope someone will like it ^_^
I originally started making it as a toonish UFO for the Ralphling.. but .. well it took on a life of its own and became much more "realistic" (if you can use that term with a UFO) than I'd planned.. anyway.. I liked how it looked so here it is.
BDDesign ( ) posted Wed, 04 August 2010 at 8:45 PM
Just wanted to say that I stumbled on this thread just now and I LOVE this UFO model. Thank you for being so generous to give it away for free!
vholf ( ) posted Wed, 04 August 2010 at 9:56 PM
Thank you TrekkieGrrrl, very generous ^^
bagginsbill ( ) posted Wed, 04 August 2010 at 10:35 PM
It's missing the texture SciFi_Wall or something like that.
Marque ( ) posted Thu, 05 August 2010 at 4:34 AM
It was the strawberry jam sandwich he had in his pocket, tell him to leave his snacks at home! Nice job on the model!    8^)
tonymouse ( ) posted Thu, 05 August 2010 at 6:39 AM
Yes very very cool!!! and this thread was very informative.
lkiilerich ( ) posted Thu, 05 August 2010 at 7:49 AM
 Thank you Trekkie what a great gift :-))))
HUGS
Lene
Haarspalter ( ) posted Thu, 05 August 2010 at 8:05 AM
With photoshop as a Postwork are some minutes of work and one saves a lot of frustration.
RobynsVeil ( ) posted Thu, 05 August 2010 at 9:51 AM
Quote - With photoshop as a Postwork are some minutes of work and one saves a lot of frustration.
Just like with doing render GC instead of fixing non-GCed renders in Photoshop, it's always better to fix material/shader/lighting/render problems before the final render rather than in postwork, if only to discover what caused the problem in the first place (so you can prevent it and similar issues in the future).
Brilliant thread!
Metaphor of Chooks
TrekkieGrrrl ( ) posted Thu, 05 August 2010 at 11:25 AM
 BB - the SciFi wall should be in Poser, it's one of those old "procedural" textures AFAIK it has been there since Poser 5...
Now i'm worried. I thought everyone had that file... :( Did you ever install the Legacy content? I know I used my PP2010 version to make sure it was still present....
bagginsbill ( ) posted Thu, 05 August 2010 at 12:38 PM
Oh - well no I don't have that, but only because I just switched to a new laptop. I've only transferred my own runtime (stuff I made) - I don't even have the Poser Pro 2010 stuff, let alone the legacy. No worries. I'm busy with LuxRender at the moment anyway.
TrekkieGrrrl ( ) posted Thu, 05 August 2010 at 2:46 PM
 Oh good :)
Well.. not good really but you know what I mean. Good that the error wasn't on my end :)
