Wed, Feb 19, 3:53 PM CST
Forum Moderators: RedPhantom
Subject: Lock up in Poser 8 ??????????????
geep ( ) posted Wed, 04 August 2010 at 11:40 AM · edited Wed, 19 February 2025 at 3:53 PM
Has anyone else seen this when trying to change a name in the HE?
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
TrekkieGrrrl ( ) posted Wed, 04 August 2010 at 11:52 AM
 did you by any chance hit the space or a comma or something while typing the name? Sounds like it might be an invalid character.
Get that invalid to see a doc, soon! ;)
geep ( ) posted Wed, 04 August 2010 at 12:09 PM
Trekkie,
I have tried various combinations, e.g., space, no space, number, letter with and without spaces, etc. and sometimes it locks and sometimes not.
Very frustrating when it locks because the only way out (that I have found) is to use the Task Manager to "End the program" with any work that was being done, obviously, gets lost. Grrr :cursing:
(no) cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
ratscloset ( ) posted Wed, 04 August 2010 at 12:41 PM
Geep... can you let me know the exact steps, figure, and name you are using?  I want to try to duplicate it. I can not so far (you can have spaces and some other characters... and the error pops up if you use an incorrect Character, but clicking okay should take you back to the last version.
ratscloset
aka John
geep ( ) posted Wed, 04 August 2010 at 1:47 PM
Rats,
I will try to see what combo causes this problem.
Clicking "OK" just brings up the "This character combination ..." again and again and again, ad nauseum ...
... and I have not found any way out of this "dead-end" situation.
(other than to  use the Task Manager to  "End ...")
cheers,
dg
cheers,
dr geep ... :o]
edited 10/5/2019
ratscloset ( ) posted Wed, 04 August 2010 at 2:13 PM
Try deleting your Preferences.... that may be the issue.
ratscloset
aka John
geep ( ) posted Wed, 04 August 2010 at 2:24 PM
12x8 Fwall_1 appears to cause the "lockup" reliably
Removing the space, e.g., "12x8Fwall_1" still causes lockup.
Removing the "x", e.g., "128Fwall_1" still causes lockup.
(Note - The "Intenal name:" appears to have been changed to "_2" <==== ???)
Changing the "Name:" to "_2" or "_3" or "_4" appears to NOT cause lockup.
"128Fwall" causes lockup
"Fwall" does NOT cause lockup
"1" causes lockup
"poly box_1" No lockup
" poly box_1" (with leading space in name) causes lockup
Try using a number or space as the leading character in the "Name:" to duplicate the problem ???
Yes? ... No? ... Maybe ???????????????
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Wed, 04 August 2010 at 2:30 PM
Ever seen this?
First time I have seen it in Poser 8.
Clicking "OK" cleared it and I was able to continue.
May or may-not be related to original problem.
cheers,
dr geep ... :o]
edited 10/5/2019
TrekkieGrrrl ( ) posted Wed, 04 August 2010 at 4:58 PM
 That last one looks like what you would get if the firewall is blocking the library.
Did you actually search for something or was it just as Poser started? Have you made any changes to your computer? Windows updated itself?  (I just got a stack of updates for both my regular computer  with Vista, and my netbook which is using WinXP...)
bagginsbill ( ) posted Wed, 04 August 2010 at 5:06 PM
Ever seen this?
Probably unrelated. The library is asking CP what the search parameters are so it can populate the CP Search tab with various choices. It's not important and doesn't impact anything if it fails, other than you can't search CP.
It could happen if CP is down, or because the firewall is blocking the query.
geep ( ) posted Wed, 04 August 2010 at 5:09 PM · edited Wed, 04 August 2010 at 5:11 PM
Quote -  That last one looks like what you would get if the firewall is blocking the library.
Trekkie,
No, no changes were made to anything.
This error happened in less than a minute between starting Poser, having a "lockup", aborting,(using Task Manager), and then restarting Poser ...  again. :sad:
BB,
Ok, thanks. 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
ratscloset ( ) posted Wed, 04 August 2010 at 6:58 PM
Okay.. I tried space in front... no issue (error, but clicking OK reverted it) I wonder if it is content specific. Can you try this with Andy in a new scene? Also, what are all the props and Content in the Scene named... could be a factor.
If you would, take this out of the Forums as well, contact Support (Attn John) so I can some other details on this issue and your system. We can keep posting on the topic, but I do need some other details and then I can also share it with some of the Project Team.
ratscloset
aka John
geep ( ) posted Wed, 04 August 2010 at 8:38 PM · edited Wed, 04 August 2010 at 8:39 PM
John,
Tried to login and create ticket at SM but rec'd ...
"Fatal error: Unable to open file" from SM message on an otherwise blank screen.
Plse advise.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Wed, 04 August 2010 at 8:49 PM
John,
OK, sucessfully posted on SM.
The ball is in your court (figuratively 'speaking,' that is) 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
mackis3D ( ) posted Thu, 05 August 2010 at 5:21 PM
I also experienced lockups or PP2010 "freezing" but maybe unrelated to Geep's experience.
It happens when I use some Python scripts as 'Texture Filtering Off' and I use at the same time the VLC media player. No commando was taken, I had to restart PP2010 and to turn off the VLC player, then everything worked fine.
But the weird thing is I had similar problems with some Python scripts in PP2010 prior to using the SR1, then Poser crashed sometimes when I clicked an unchecked box.
Since Geep's problem with the 'Hierarchy' uses a similar popup window like the Python scripts I use, maybe something is not communicating well somewhere.
ratscloset ( ) posted Thu, 05 August 2010 at 11:29 PM
Geeps issue is not really a freeze, it is just hung. It appears to have to do with the specific prop and maybe how it was constructed and saved.
Your issue sounds more like a display freeze. Try switching to SreeD and see if it continues (NOTE: I am speaking about the crash when checking or unchecking a box, not the conflict with the VLC Player. If you could, contact Support about the Player Conflict.)
ratscloset
aka John
