Sun, Feb 16, 6:14 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: script for turning off Mat-based GC?
Vex ( ) posted Mon, 09 August 2010 at 11:13 AM · edited Sat, 08 February 2025 at 1:57 AM
I would like to include a script in my packages that disable MAT-based GC ( set a specific value to 1 ).
Anyone know if there's one available to share ( with credit of course ) or help me figure out how to make one?
Dizzi ( ) posted Mon, 09 August 2010 at 12:35 PM · edited Mon, 09 August 2010 at 12:35 PM
Could you please explain what you mean? Do you have a material what does GC and want to change the value of a node with a certain  name? Or do you want to disable GC (Poser Pro) for some texture names?
Vex ( ) posted Mon, 09 August 2010 at 1:04 PM
 Bagginsbill's VSS shader has built in GC. I would like to use that, but supply a script to turn it off ( set PM:Gamma node to 1 instead of 2.2 ) so that if you want to use the renderer GC instead of mat GC, you don't have to go around editing every mat zone with it, just 1 click done.
Dizzi ( ) posted Mon, 09 August 2010 at 2:01 PM
file_457333.txt
This would work for the current selected figure:
value=1.0
for mat in poser.Scene().CurrentFigure().Materials():
        shdrTree = mat.ShaderTree();
        if shdrTree!=None:
                for node in shdrTree.Nodes():
                        if node.Name()=="PM:Gamma":
                                node.Input(1).SetFloat(value)
The attached script allows to set the gamma for the current material, actor or all materials and to do it for maps that should not be corrected (Displacement, Bump...), too. It's for Poser Pro 2010 only, though.
Vex ( ) posted Mon, 09 August 2010 at 2:19 PM
 thats fantastic. thank you so much! =)
bagginsbill ( ) posted Mon, 09 August 2010 at 7:43 PM
Thanks dizzi. I'm under a deadline at work and have very little time for Poser stuff today.
Vex - it is possible to make the gamma value automatic.
Change the gamma node to a subtract, and add two more nodes.
Isaoshi wrote how here:
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3644388&ebot_calc_page#message_3644388
Since this handy idiom was revealed, I'm making all my shader GC automatically shut off when render GC is enabled.
bagginsbill ( ) posted Mon, 09 August 2010 at 7:45 PM
Note - looking down that thread, I see you were already there, proclaiming that you feel dumb.
grin
