Try hiding the toes? Using "Hide" works well for parts of the body that are going to be covered up with the cloth/shoe anyway.
say." - Ghandi
Check to see if IK is turned on for the SHOES. I've run into this with things I run through Wardrobe Wizard... sometimes IK gets turned on for the clothing item, and it produces results like those you describe.
It would sure be nice if SM would give us the ability to turn IK off for EVERYTHING globally. It's a great idea for animators, but a pain-in-the-rear for the rest of use.
Hmmm... What about it, Ratscloset???? :) :)
Quote - Check to see if IK is turned on for the SHOES. I've run into this with things I run through Wardrobe Wizard... sometimes IK gets turned on for the clothing item, and it produces results like those you describe.
That does not seem to be the problem with the shoes I am working with now. The option for Use Inverse Kinematics is not available for the shoes.
I've run into this problem too; in Carrara actually.
I'm pretty sure the issue is that the shoes were created around a posed foot/toe instead of the default V4 OBJ; hence the shoes conforming too low.
Some of the offending figures required an injection pose to work; more than simple rotations.
I never got a straight answer out of anybody, so I ended up converting the shoes to smart props, seeing as how they didn't have toes...
I wanna give certain merchants who do this half-ass crap a piece of my mind, but I'm just not a confrontational kinda dude...
The issue has to do with the content is designed with a different endpoint than the base figure. With improvements and fixes to the conforming figure system, a few types of imprecise or erroneous states in third party content may cause that content to conform with issues. For example if content contains a combination of incorrectly saved joint origins and very tight parameter limits (0,-0), it may now behave unexpectedly. I am trying to find some details on it, but contact the Vendor. Most are aware that they have products constructed in this manner.
ratscloset
aka John
Smith Micro told me - after a bunch of back and forth messages - that is has to do with a more accurate set of parameters from SR1, and that the vendor must fix their products. I asked if there were some adjustments I could make in Poser and was told it was not a Poser issue. However, there has got to be a good way to work around this. I can't wait for a bunch of vendors to maybe do a product upgrade. What is a good process for saving as a smart prop, etc.? That sounds promising.
thanks
I e-mailed one of the vendors and they said "Since Smith Micro changed the conforming foot option in SR3, all the platform shoes are effected by this problem, by most vendors". I can understand vendors not wanting to spend a lot of time correcting an issue they may not have had any control over. I would spend a nominal amount of money to get an upgrade to conform properly in Poser Pro 2010 for most of the products I have.
Has anyone played around with using the shoe dials to fit the shoes? I did a little, and it did not take much time to get the shoes to fit, but I don't think I got them to fit perfectly (like they fit in Poser Pro). I can't compare because I took Poser Pro off my computer when I got Poser Pro 2010.
Here's a few ways to convert the shoes to smart props...
Firstly, this only works with "below the shins" shoes.
Any-who...
The first and easiest way is to convert them in an older version of Poser where the shoes still work. (Like P7)
In Poser Pro you'll probably have to create the props from the shoe figure and manually line them up with V4's feet; which can be a PITA
There's probably a better way to do this, but it works for me. The UV mapping should remain intact too :)
Some of the shoes for V4 that I have been using in Poser Pro and Poser 7 will not conform correctly in Poser Pro 2010. When added to the V4 figure and conformed to V4, the shoe is rotated so that the toe of the shoe is below the toe of V4. This relationship remains the same after applying the foot pose to V4. I can get the shoe to fit with the shoe bend and side to side dials, but this was never a problem in Pro and P7. Other shoes conform with no problem.
