Sun, Feb 9, 4:16 AM CST
Subject: Poser 8 Talk Designer
Mavrick21 ( ) posted Wed, 04 August 2010 at 8:20 PM · edited Mon, 03 February 2025 at 5:50 AM
Am I missing something?  I cannot find a sound format that will work with Talk Designer.
.wav will not work...
Thanks
TrekkieGrrrl ( ) posted Wed, 04 August 2010 at 8:25 PM · edited Wed, 04 August 2010 at 8:25 PM
 Wav WILL work. However... for some obscure reason, there are some WAV's that can't be read by Poser. Try re-saving them by running them through some standard format like Window's Sound Recorder...
I THINK (from my flaky memory) that they need to be 8 bit, and some programs save wav as 16 bit... Don't quote me on that though L  My wavs has always worked with Talk Designer - but then again I've never used it much. Used it, yes, but mostly for the novelty value :)
ratscloset ( ) posted Thu, 05 August 2010 at 6:56 AM
This is generally a Sound Driver issue or an OS System Issue (Vista and Windows 7) Contact Support, ATTN John and I will get you the steps to fix
ratscloset
aka John
Mavrick21 ( ) posted Thu, 12 August 2010 at 8:45 PM
Thanks for the replies.  I made a technical ticket on this issue with Smith Micro but no response yet.  Suprised others dont see this problem.....or hear.
Mav
rokket ( ) posted Fri, 13 August 2010 at 8:17 AM
Quote - Thanks for the replies.  I made a technical ticket on this issue with Smith Micro but no response yet.  Suprised others dont see this problem.....or hear.
Mav
I have used 16 bit and 8 bit .wav files with Poser 8 talk designer with no problems other than over doing the enunciation part.
check out recording software like Reaper. You can render your .wav files to suit the program wit h it.
link for the user guide before you decide to download it:
http://www.reaper.fm/userguide.php
ratscloset ( ) posted Fri, 13 August 2010 at 8:17 AM
Mav
Send me the incident number if you still do not have a reply (Site Mail and include your email address so I can look it up and respond)
ratscloset
aka John
