Fri, Nov 22, 12:27 PM CST
Subject: Rendering postwork
xpdev ( ) posted Fri, 13 August 2010 at 9:30 AM · edited Fri, 22 November 2024 at 7:13 AM
what type of postwork I need to apply to poser render to get a good effect  like over ?
Many thanks.
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
Daymond42 ( ) posted Fri, 13 August 2010 at 12:29 PM
Well... not really postwork, per se... but I'd re-render the right foot with an Area Render after adjusting her toe angle so that her big toe is touching the ground.
Currently using Poser Pro 2012 (Display Units = feet)
AMD Phenom II 3.2ghz (6 cores)
8gb RAM
Windows 10 Pro 64bit
ice-boy ( ) posted Fri, 13 August 2010 at 12:58 PM
you rendered this in poser?
Winterclaw ( ) posted Fri, 13 August 2010 at 1:26 PM
I think he's asking how to post work poser in order to make it look like the image above... I almost want to say that was rendered in vue or something like that.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Daymond42 ( ) posted Fri, 13 August 2010 at 1:29 PM
Even if that's the case, Winterclaw, my comment still stands. :)
8gb RAM
Miss Nancy ( ) posted Fri, 13 August 2010 at 1:29 PM
 img downloaded from porno site. he wants to know how to render in poser (GI/IDL/VSS/hdri,
 not visible in raytracing for trans surfaces, et al.)
TrekkieGrrrl ( ) posted Fri, 13 August 2010 at 7:36 PM · edited Fri, 13 August 2010 at 7:37 PM
 Actually there are several faults with this one. The lighting is wrong (VSS and some proper lights would do wonders) - the right toe isn't touching the ground and both pinkies are embedded in her skin...
At first glance it's an ok render, until you start nitpicking L
xpdev ( ) posted Sat, 14 August 2010 at 1:58 AM
That's right miss nancy, i want to konw how is possibile to render at this level.
Can you explain me "GI/IDL/VSS/hdri,  not visible in raytracing for trans surfaces"  ?
Many thanks.
Miss Nancy ( ) posted Sat, 14 August 2010 at 5:24 PM · edited Sat, 14 August 2010 at 5:32 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3538588&ebot_calc_page#message_3538588
see att lnk - freebie envdome (lighting; use hdri on it) and VSS (skin).  see above - maxxed-out GI render settings.  the others will suggest changing these settings.  it takes about 18 mos. to learn how to 90% of this in poser IMVHO.  in poser, GI is called IDL, as there's no indirect specular for now.  the above is for poser 8.  I dunno if VSS works in that as easily as in PP2010.  the shadows should be ray-traced, but with only hdri and no directional lites, that's what ya get.
hborre ( ) posted Sat, 14 August 2010 at 6:03 PM
Trial and error.  And also learning from others mistakes.
