I think he's asking how to post work poser in order to make it look like the image above... I almost want to say that was rendered in vue or something like that.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Actually there are several faults with this one. The lighting is wrong (VSS and some proper lights would do wonders) - the right toe isn't touching the ground and both pinkies are embedded in her skin...
At first glance it's an ok render, until you start nitpicking L
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3538588&ebot_calc_page#message_3538588
see att lnk - freebie envdome (lighting; use hdri on it) and VSS (skin). see above - maxxed-out GI render settings. the others will suggest changing these settings. it takes about 18 mos. to learn how to 90% of this in poser IMVHO. in poser, GI is called IDL, as there's no indirect specular for now. the above is for poser 8. I dunno if VSS works in that as easily as in PP2010. the shadows should be ray-traced, but with only hdri and no directional lites, that's what ya get.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Many thanks.
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
