Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 11:01 pm)
Quote - Thanks Kevin, so am I correct to assume that the material name on a portal in the .lxo file must be "portal" to have luxrender recognise it as a Portal?
That been said, portals won't help you with your Warehouse scene, since it's an exterior.
Portals are useful for limiting the directions the engine will be looking for light sources in; In this case the only direction there is no light is the ground (the sky is an area light)...
(If you're just talking generally, disregard)
Understanding how to set up portals is going to be good in general of course.
But I was also thinking that maybe the interior of the warehouse might be causing a lot of extra bounce calculations and creating a portal where the door is could then maybe improve efficiency?
Software: OS X 10.8 - Poser Pro 2012 SR2 - Luxrender 1.0RC3 -
Pose2Lux
Hardware: iMac - 3.06 GHz Core2Duo - 12 GB RAM - ATI Radeon HD
4670 - 256 MB
Quote - Understanding how to set up portals is going to be good in general of course.
While you're right of course, I think it's a minor feature, as it only serves to accelerate a very specific type of render (interiors with windows to a "daylight" illuminated exterior).
Quote - But I was also thinking that maybe the interior of the warehouse might be causing a lot of extra bounce calculations and creating a portal where the door is could then maybe improve efficiency?
I don't think this should make any visible difference. Not any more than the barrels...
The problem isn't bounce calculations, but the ray going for the camera looking for a light source (we're rendering bidirectional): It might make a big difference if 80% of the scene is a light proof wall, but the 5% the door represents in this case shouldn't make any big difference, I think.
Quote - OK, how is the new version supposed to work? I do get the GUI up, and after making selections, I press 'OK', and nothing happens. If I run the python script, I get an error that global parameters are not found.
The GUI is not integrated yet. But you can use the GUI to set some parameters. If you click "Ok", the parameterfile is written to disk and used from the exporter.
Run the GUI, click OK.
Start the exporter.
Start Lux.
Putting anything together should be ready to play with this weekend.
To have a Lux-render beginning at the last point you left it (after closing Lux), a parameter has to be set:
write_resume_flm | bool | Toggles the rendering resume output. Luxrender will auto-resume a rendering if the resume file exists. (NOTE1: the resume feature doesn't include any sanity check, do not forget to erase the file if you are starting a new rendering or you have modified the scene description. NOTE2: the resume file is usually read between 10-30 secs after the start of the rendering. NOTE3: this feature works well only with progrsive pixel samplers.)
Some more parameters added
Download last version as usual: http://www.poserprofis.de/PoserLuxExporter_Alpha
I have to quit for today. More tomorrow (german local time).
There's a nice little installation guide here: www.luxrender.net/v/exporter_blender
As for Blender's interface, I learned enough to at least get a scene out of LuxBlend. You can go to 'Render' in the menu bar and select the LuxBlend Exporter. Blender has a cube auto-loaded in the default scene, so you can just fiddle with the LuxBlend settings as you will. If you want to play with the Blender materials, you just have to go to the first drop-down on the bar and choose "SR:3-Material", and that'll bring up the materials window. You can convert them to Lux materials via the "C" button on the material list in the LuxBlend window.
I was mostly just changing settings and hitting the 'render' button on LuxBlend, then opening the .lxs file and looking at what it wrote.
currently using Poser Pro 2014, Win 10
Quote - There's a nice little installation guide here: www.luxrender.net/v/exporter_blender
I read that. It says to put the exporter in the Blender scripts folder. In Blender 2.5 there is no such thing.
Quote - i noticed something.
luxblender has a recommended render setting called Final MLT/Bdir path tracing..
the problem is see is that the number of bounces are 5. i mena the lowest you can get is 5. this is to much for me. i use 2 or maybe 3 bounces.
Don't worry. I have a "bounces" parameter in my GUI. And I'll be adding "Preset" support to the GUI next week, so that users can create and share presets. This will apply to every part of the configuration. You'll be able to make or use render presets and tone mapping presets and all sorts of things.
Quote - I read that. It says to put the exporter in the Blender scripts folder. In Blender 2.5 there is no such thing.
Ah. I downloaded 2.49b, where there is such a thing, in a subdirectory of the installation directory. 2.5 is still in testing, according to the site. Really, it works, I only downloaded it four days ago, myself... :}
LuxRender works with blender 2.53, you just need the new version of luxblend from their source repository.
http://github.com/doughammond/exporterframework/archives/fcd2fd7cd7d046d63de50d90016e0a906ccc2e4f
copy ef folder to blender2.53scriptsio
http://src.luxrender.net/luxblend25/archive/76aaf3629dd6.zip
copy luxrender folder to blender2.53scriptsio
Quote - i hope i am using the wrong settings.
rendertime 1 hour .
Actually, that's quite short for Lux ;o). If you think LuxRender is going to be fast, think again. It's slowness can be compared to Vue if you've ever used that. Takes much longer than Firefly. It's upside is that it's much more realistic than Firefly. You'll have to compromise time for realism.
Quote - erm Ice. you do know that Lux is not a fast renderengine. it's a correct engine. that takes time. anywhere from 10 minutes to 10 days.. depending on how long you let it run, what setting etc.
(there is a faster GPU/CPU/Network version coming but there is no date on that yet)
a fast render engine would render this in 2010 in 2 minutes. so please without posts like this.
i let it render 1 hour and it has hard noise.
Maybe you should read back through the thread again. I know you came into it somewhere in the middle.
No one ever said it was gonna be faster, just more realistic. It's much, much more slow than what you're used to with Firefly, at least right now. Think of it more like something you'll let render overnight or while you're at work during the day...lol.
Quote - We're TRYING to tell you that Lux is NOT fast! Even with simple. If the render times bother you that much, then you might wanna think about not using it.
i thought that luxrender is a fast raytracer with simple coding.
now i have a feeling that guys who have no idea what they are doing just made a monte carlo raytracer for free.
if only bagginsbill would work on this code for 6 months(for a paycheck). we would be in heaven.
Quote - Maybe you should read back through the thread again. I know you came into it somewhere in the middle.
i know that its not faster. its doing realistic soft reflections. i knwo that it can not be faster. its normal that its slower.
i just thought that for a one hour render it was very bad. i guess i didnt know better sorry.
Quote - > Quote - We're TRYING to tell you that Lux is NOT fast! Even with simple. If the render times bother you that much, then you might wanna think about not using it.
if only bagginsbill would work on this cde for 6 monts(for a paycheck). we would be in heaven.
Here's the thing ice-boy. Lux is unbiased. I'm probably not the one to go into the technical details of that (I'll give the floor to BB on that one), but unbiased is slow. That's just the way it is. All unbiased render engines that don't make use of the GPU are slow. And until Lux does (it's in the works), it will be slow. It will probably be somewhat slow even after it makes use of the GPU, just not AS slow...lol.
Quote - > Quote - > Quote - We're TRYING to tell you that Lux is NOT fast! Even with simple. If the render times bother you that much, then you might wanna think about not using it.
not if your name is Arnold heheheheheeheh ;)
www.graphics.cornell.edu/~jaroslav/gicourse2010/giai2010-02-marcos_fajardo-slides.pdf
Quote - not if your name is Arnold heheheheheeheh ;)
Hehe....well, Lux and Kerky are both free - how much can we really complain ;o).
Well, read back a few posts....someone was mentioning something about indoor scenes and something extra that had to be done with them. That may help you :o). I wish I could explain it to you here, but I can't . I just haven't read up on Lux enough yet to do that ;o). Look back just one or two pages and I think you'll find it. Right about the spot where (Flenser, I believe) posted an image of Stonemason's Warehouse.
You need to use portals for interiors with light coming in from outside. I don't know about inside lighting. There are tutes available that have settings. Do a Google on luxrender portals. Arnold has similar problems with interiors. And Arnold is not readily available and who knows when it will be and for how much. It's very nice, but free and ready now is better. :)
Here's the tute I posted earlier for portals... info near bottom of page...
http://www.luxrender.net/wiki/index.php?title=LuxBlend_tutorial:_creating_a_simple_interior_scene
There is an interior light in the scene.
I did opt to try Octane Render and hopefully this weekend I'll have time to finish my new computer (I finally have all the parts for) to use it. I like the results I've seen from users so much I bought two licenses!
Kevin
Quote - i am sorry for posting bad posts. but i never was trying to complain.
i was just wondering if i am using wrong settings.
it was not a problem that it was not finished at 1 hour. it was strange to me that it looked so bad after 1 hour with so simple geometry.
Unbiased render-engine means to simulate the reality as close as possible. Lets have a look on your scene. There is a view into a room and an "infinitive world" outside. High and far away from your room is a lightsource, the sun.
To let you see something a renderengine has to send out "rays". This rays are "traced" and -simply said- a colorpoint is set where the ray colides with something. As said, the only lightsource from where rays are sent out is your sunlight. A real lot of the rays do not hit anything. Because your room is very small compared to the outside "world". A biased renderengine tries to optimize rays sent. An unbiased engine does not (like reality).
But because sending rays against nothing isn't that effective Lux has a method to give some hints to the raytracer. These hints are called "portals". Simply said a portal is a geometry (mostly a plane) that says: "Raytracer, all light to me!" Such portals are put where windows and doors are (where the light comes into your room). This helps a lot.
Beside of the portals, there are many more things you can do to speed-up your render or get better results. But the problem is, it depends on your unique scene. So you have to know something about Lux-.internas or you have to live with what you get.
At the moment this project is in an early alpha stage. It's not that easy to prepare a Poser scene to be used with Lux. But we are working on this problem.
(Whoever means he/she could help with something: Just step in and do; even hints, findeouts, special know-how or script-snippets are important. This is an open project for all Poser users. The more know-how we can concentrate on this project the better is the what comes out at the end.)
I really wished my english would be better - sorry -
Quote - so i tryed now a render with only a light inside. and in 30 minutes it rendered better then the one in 1 hour.
so yes i will wait because it looks like i am using bad settings.
I think it has been mentioned before, but you have to use Portals for interior scenes, so Lux doesn't do samples for things out of sight.
Here are some hints from the Lux-FAQ:
First, please note that even on powerful machines, certain scenes might take over 12 hours to get satisfactory results (and much more with high resolutions). However, there are several things one can try in order to get satisfactory results quicker.
Quote - Added some more parameters from the GUI.
The parameter names used from the GUI should be the same as those used in the documentation. Otherwise another conversion must be done and user aren't able to have a quick view in the documentation.
adp - your coding style would give you that opinion, but I already took care of it.
def s2lux(x): return x.lower().replace(' ', '')
And I put this as a filter on my dictionary object.
But if you want to type all those explicitly, please do so.
In the choices, you can put just a label, or you can put the label, a vertical bar, and the actual value.
For example:
PushRadioGroup dataProvider=First Choice|firstchoice, Second Choice With lots of Words|2nd choice, etc. etc.
ComboBox dataProvider=Alpha|1, Beta|2, Delta|3
I find it unnecessary to type all that given that a simple one-line filter takes care of it.
Frankly, adp, I'm taking a break but soon I will catch up to you. I don't like all the extra typing you go through. For example, why do you have all the global parameters passed around - they are GLOBAL PARAMETERS. Put them in a global place and just import them.
Why do you use dictionaries instead of objects? Do you prefer:
global_parameters["Camera"]["focalLength"]
I prefer
globals.Camera.focalLength
or even better:
Camera.focalLength
I plan to rewrite everything that exports anything pretty soon. You keep writing your way if you like. I will be done pretty soon - maybe a week, maybe two - with everything.
But for now I'm taking my week-end break.
Ice, if you are doing an indoor scene with light coming from outside you should create a portal where the light is coming in, that tells lux not to waste processing power on irrelevant areas. Read back through the posts made yesterday.
As you've noticed putting a light inside is going to make rendering faster.
Luxrender is very precise and gives realistic results, that takes time. The good thing though is that it's very easy to add extra network nodes for more rendering power, and once the GPU rendering code is finalised the speed is going to increase by a factor of 10-50x.
Pose2Lux
4670 - 256 MB
Actually, it seems to me that - with the metropolis sampler, anyway - renders do not necessarily get better the longer you let them cook. I usually stop my little test renders after two or three hours because I think they look good enough. The one time I left one to render overnight - without changing any of the settings, mind you - it ended up terrible.
