DAZ|Studio F.A.Q (Last Updated: 2024 Nov 13 1:29 pm)
Hi Elele,
The best way to accomplish your task is to save your customer character, with the morphs dialed to at least 1.0 on the parameters tab, to a CR2.
THEN, in Morphing Clothes, load your NEW CR2 with the morphs as the character. You can then transfer the morphs to your bathing suit.
Hope this helps.
Thank you for your reply, I tried it, but unfortunately the result is the same: the morphs are injected into the swimsuit (and they work) but the swimsuit doesnt take the shape of a character that has the same morphs at different values, it just keeps the shape of the standard V4 model (unless i adjust every morph of the swimsuit to the correct value)...
DAZ Store: http://www.daz3d.com/elele
Renderosity Store: https://www.renderosity.com/mod/bcs/vendor/elele
Deviant Art Page: http://eleleoke.deviantart.com
This may be a consequence of the way the morphs are being named. I don't have Morphing Clothes, but if there's an option to give the new morphs in the clothes the same name (not necessarily the same as the label you see in the Parameter palette, unfortunately) as those in the figure that's what you want. Otherwise you need to work out whaty names are being applied to the new morphs and to the figure morphs and then use a text editor to rename the new morphs to match the figure's.
yes, i have everything enabled, except "hide cotrolled morphs" and "clothing is skirt"
i followed this quick guide:
On the left I have my values set as follows:
7
3
1
0.05
0.07
I have all boxes checked excpet the Skirt check box (unless I am doing a skirt then its unchecked) and Hide Controlled Morphs is not checked either
For output I always choose a New Copy of the clothing option. MC should have created a folder called "!Converted" under the Character folder and so from the Transfer Tab I choose the Path button and point it to the !Converted Folder then I copy the original file name from the Clothing Tab at the top and paste is on the output line and then alter the name to reflect its different.
Transfer!
To access the new version of the clothes, goto the !Converted folder under Characer and load the new clothes.
Hello,
I bought the "morphing clothes" program from this site.
I made a swimsuit in daz hexagon and saved it as .obj
loaded it in studio and made the bonestructure with figure setup tools, so the swimsuit fits and moves with the body
Now i want to inject the morphs into the swimsuit with the morphing clothes program. So i tried it and saved the swimsuit as a new file and it does indeed contain the morphs, BUT when i load the swimsuit to a custom character, it doesnt take on the morphs, i have to input every value for every morph... Also if i adjust the character morphs while shes wearing the swimsuit, again the swimsuit isnt adjusting
Is this the way it has to be with this program or am i doing something wrong? I want the clothing to fit a custom character without having to put every single value in... Like pretty much all the clothing i have.
Thank you,
Elele
