Mon, Jan 13, 2:29 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: P8 obj export
Einzelganger ( ) posted Sat, 21 August 2010 at 2:52 AM · edited Sun, 12 January 2025 at 12:08 PM
Lo
 I am trying to export still/frames out of poser in .obj format, trouble is it just exports 0kb files
is there something i am missing?
tia
 Einzelganger.
gryshnak ( ) posted Sat, 21 August 2010 at 6:54 AM
What steps are you going through?  Are you selecting the checkbox for all the items you want exported?
Einzelganger ( ) posted Sat, 21 August 2010 at 7:12 AM
yup, and leaving the ticks in the next box as they are.
it gets as far as showing the saving window, then finishes
but all it has output is 0kb files.
DarkEdge ( ) posted Sat, 21 August 2010 at 7:30 AM
Try checking the UNIVERSE box, which deselects everything, then check the V4 box which will select V4.
Maybe this will help Poser get out of whatever weird loop it is in. I can export obj's in P8.
gryshnak ( ) posted Sat, 21 August 2010 at 8:12 AM
Try creating a primitive shape like a sphere or cube in P8, and see if you can export that as an obj.
What happens if you export in another format, say Collada?
Einzelganger ( ) posted Sat, 21 August 2010 at 8:18 AM
heh, was doing that as you posted :D
but even a simple sphere wont export
i run poser as admin, so i don't think its anything like that
other formats export something
though some export  garbage (collada)
TrekkieGrrrl ( ) posted Sat, 21 August 2010 at 8:21 AM
 Have you upgraded to SR3? Poser 8 in its early versions had problems with obj exporter on European systems, the ever-present comma issue I think.
It was solved in later SR's I thing even SR1, but not sure. I can export objs just fine from mine, Danish Windows,  P8 SR3
Einzelganger ( ) posted Sat, 21 August 2010 at 8:24 AM
yup, i have 8.0.3.11793
TrekkieGrrrl ( ) posted Sat, 21 August 2010 at 1:04 PM
 PERHAPS Poser's exporter has been corrupted then. I'd try reinstalling Poser on top of itself to make sure it's updated
