Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Same happens to me with PP2010 during long renders. Screen comes back briefly if I move the mouse. Once the render is complete the screen stays on okay. I'm guessing the monitors aren't getting any signals and so go into sleep mode when the CPU is busy. CPU is a i7-860 quad core.
You could look at your power settings in the control panel.
Also Windows 7 Ultimate 64 bit, but using two 5000 series graphic cards running 3 Samsung monitors.
Oooooooooh!! Nice sounding rig ws99pf!!!****
I know it's not a low power mode switch as I being the lout that I am have always disabled power saving this that and everything be it pc or otherwise!! LOL!!
I'm stumped though... can't figure it out on my own bothers me immensely!!
Gerard******
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
Hope it's not the video card as it's only been in use for a little over a year!! :(
But on a positive note I changed render threads to just use 1 core in both PP2010 and Max and it seems to have done the trick as markschum suggested!! I'll try it in Lux after the Max render is done!
Mind you both renders did seem to take longer but I can live with that!!
Gerard
The GR00VY GH0ULIE!
I'm going to try a new PSU tomorrow I think!! It'll suck if it's the video card though!! Mind you I could get a new GTX 480 or sumpin then!! Hmmmmmmm...
Gerard
The GR00VY GH0ULIE!
i had the same issue a while back go into gfx card settings while using poser or any other high gpu use program and set the video option to use 1 gpu rather then 2.
the hit graphically isn't noticeable, and it should fix your issue. remember to set it back after for playing games or whatnot. or you could always set a profile to change every time you start poser(easiest way)
good luck
Hi!
Whenever rendering in either Poser (PP2010 & P8) 3D Studio Max or LuxRender my monitor will go black and flash the monitors "No Signal" message but it comes back on within seconds. This has been happening quite a bit since last week and I've made no changes prior to that. I have since updated my GTX 260 drivers to the latest 258.96 Nvidia drivers and Viewsonic monitor drivers and it hasn't happened as often but it still persists and I'm curious if there's something really wrong with my pc!
Athlon 64 X2 @ 2.6ghz
4gb DDR2 ram
GTX 260
and standard hd's n stuff!
Any ideas or help would be awesome!!
Gerard
The GR00VY GH0ULIE!
