Fri, Jan 10, 5:48 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: 3D Text
Vanzagar ( ) posted Sat, 28 August 2010 at 2:27 AM · edited Wed, 08 January 2025 at 7:39 PM
Is it possible to do 3D text in Poser, would like to try and create a fancy 3D animated title maybe...
Thanks,
Vanz
Acadia ( ) posted Sat, 28 August 2010 at 3:00 AM
http://www.armanisoft.ch/webdesign/elefont/Elefont.html
You can try Elefont. It was recommended in the following thread:
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3499826
I wasn't able to get it to work very well. I had all kinds of choppy/spikey edges, not smooth rounded.  But give it a try. Others seem to be able to get it working better than I did.
seachnasaigh ( ) posted Sat, 28 August 2010 at 6:08 AM
You're not doing anything wrong, Acadia;  Elefont does produce "icicle" artifacts, especially if using the fancy bevel types.  It also leaves an array of loose vertices around each letter, apparently marking kerning limits.
Also, Vanzagar, be aware that Elefont's output is .dxf format, which Poser sometimes has trouble importing.
I import the .dxf into the modeler Silo, fix the geometry quirks, then export the repaired version as an .obj for import into Poser.
If you don't have a modeler, then just import the .dxf into Poser, enter the (advanced) material room, and use the grouping tool to select the offending "icicle" polygons and assign them to some new group.  Now select all poly groups except the icicle, and create a new prop of that selection.  The new prop won't have the icicles.  However, you may find that removing the icicles left noticeable holes.
SamTherapy ( ) posted Sat, 28 August 2010 at 6:20 AM
Wings has the ability to convert fonts into 3D models and it's a full featured, free modeller, too.
geep ( ) posted Sat, 28 August 2010 at 7:01 AM · edited Sat, 28 August 2010 at 7:02 AM
Yup, what Sam said ... a couple of clicks and you're there ! ... 👍
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
SamTherapy ( ) posted Sat, 28 August 2010 at 10:49 AM
While we're on the subject, I have a problem specific to this...
There's a particular font I want to make into 3D objects and so far I've had no luck with it.  It's called "Batman Forever" but for some reason, Wings doesn't like the name or whatever name the system cares to display.
Any advice?
seachnasaigh ( ) posted Sat, 28 August 2010 at 12:19 PM · edited Sat, 28 August 2010 at 12:23 PM
Is this it?
Elefont didn't have any problem with it - I used the large 45' bevel option.
Both the filled and the outline variants are TrueTypeFonts;  some apps specify only TTF.  I have more than once snuck an OTF (OpenTypeFont) past Elefont successfully, though.
SamTherapy ( ) posted Sat, 28 August 2010 at 8:00 PM
Yep, that's the one.  Wings don't like it, for some reason.
MatrixWorkz ( ) posted Sat, 28 August 2010 at 8:07 PM · edited Sat, 28 August 2010 at 8:09 PM
 I use Carrara for my 3D fonts because of all it's nifty beveling choices. Wasn't Carrara 7 Pro just offered for free with 3D World magazine or some such offer?
My Freebies
pakled ( ) posted Sun, 29 August 2010 at 12:09 AM
I wonder if it's the space in the fontname. Maybe make a copy and rename it with no spaces, Sam?
I've done Wings 3d lettering, but often find I need to smooth it.Er suppi 'works!'...;)
geep ( ) posted Sun, 29 August 2010 at 7:35 AM
Hi pak,
Tried that ... didn't seem to make any difference.
Interesting though.
Font DOES show up and can be used in PSP and Carrara.  ???
cheers,
dr geep
P.S.  Looking at the file properties notes that ...
File Edittability: Restricted <=== maybe this has something to do with the problem ???
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sun, 29 August 2010 at 9:22 AM
Hey Sam,
It works in Wings ............ except that ... Hmmm ... see image, especially the outline font :sad:
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sun, 29 August 2010 at 9:27 AM
And ........... a close up view of the "... Outline" font.
Could it be that Wings checks the geometry and says "Uh uh, not gonna work."
And the plot sickens ... 😄
cheers,
dr geep ... :o]
edited 10/5/2019
SamTherapy ( ) posted Sun, 29 August 2010 at 4:08 PM
Nice one, Doc.  It wasn't the outline font I wanted to use, just the standard one.  The problem is, Wings can't even find it on my system.  It's installed but for some reason, Wings can't find it.
I'm using Windows XP, which seems to truncate some of the font filenames to things like Batma~ and other such useful stuff.
geep ( ) posted Sun, 29 August 2010 at 5:10 PM
My Wings can't find it either ... if you try to use the "Browse" function ... BUT ...................................... I don't know why ... but ... if you **type in the Font name** (complete path), it seems to work.
BUT ...... for some strange reason, the letter "B" in the "... Alternate" font auses a problem.
Solution to this problem will be posted next ...
Stay tuned ... ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sun, 29 August 2010 at 5:12 PM
The letter "B" works if I change the edge bisections from "0" to "1"
Have fun ... :lol:
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
SamTherapy ( ) posted Sun, 29 August 2010 at 6:17 PM
I tried typing in the font name and it didn't work for me.  Boo hoo.
I need to install the new version of Wings; maybe I'll have better luck with that.
geep ( ) posted Sun, 29 August 2010 at 6:42 PM
Paul,
Yup, couldn't hurt ... Did you type in the complete path?
e.g.,"c:/Windows/Fonts/BatmanForeverAlternate" <=== (on my 'puter)
Spelling errors? ... Just a thought.
FYI - I am using Wings 1.2 (maybe not the latest)?
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
SamTherapy ( ) posted Sun, 29 August 2010 at 7:51 PM
Hi Doc.  I typed in the full path and name and - as you know - I never make speeling erorrs.  ;)
The good news is, your method works perfectly in the new version of Wings. Yay!
Many thanks for your help.  👍
geep ( ) posted Sun, 29 August 2010 at 8:33 PM
:biggrin:
My pleasure.
I'm glad it worked for you.
Um, me thinks you might want to get an updated version of Speelchec, also, no? :lol:
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
SamTherapy ( ) posted Sun, 29 August 2010 at 8:45 PM
:lol:
geep ( ) posted Sun, 29 August 2010 at 9:32 PM
Paul,
My, you're up awfully late ........................ or awfully early,no?:lol:
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
SamTherapy ( ) posted Sun, 29 August 2010 at 9:59 PM
Very late.  The little guy wasn't sleeping too well.  I stayed up just in case he wakes, so as not to disturb Claire.
geep ( ) posted Sun, 29 August 2010 at 11:31 PM
Whatta guy ! 😄
Does Purple know she married a Prince? :huh:
cheers,
dr geep ... :o]
edited 10/5/2019
Porthos ( ) posted Tue, 31 August 2010 at 8:24 AM
If you own either Hexagon or Vue, they do 3D text - I did this one in Vue! :)
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
