Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 01 3:49 pm)
Take it into the set up room and open the hierarchy editor.
Select an IK chain.
Hit the delete key.
Thats it :)
Sounds like it should work in the Pose room but I found that was not always the case so I use the set up room.
Then because you have gone into the set up room Poser may create a new OBJ file for it, if so just edit the CR2 to point back to the original.
Quote - Or another way is to open the CR2 in a text editor, go to the very bottom of the file and in-between the weld and add child statements you'll see 4 lines that are inky Chain...just delete those and save!
I thought that you might be able to do that but I wasn`t sure if it would mess up the cr2 in some way.
inkyChain LeftLeg
off
name LeftLeg
addLink lThigh:1
addLink lShin:1
goal lFoot:1
linkWeight 0 1
linkWeight 1 0.2
inkyChain RightLeg
off
name RightLeg
addLink rThigh:1
addLink rShin:1
goal rFoot:1
linkWeight 0 1
linkWeight 1 0.2
inkyChain LeftArm
off
name LeftArm
addLink lCollar:1
addLink lShldr:1
addLink lForeArm:1
goal lHand:1
linkWeight 0 0.2
linkWeight 1 0.04
linkWeight 2 0.008
inkyChain RightArm
off
name RightArm
addLink rCollar:1
addLink rShldr:1
addLink rForeArm:1
goal rHand:1
linkWeight 0 0.2
linkWeight 1 0.04
linkWeight 2 0.008
There are also two lines relating to the IK chains in the goal actors (hands and feet), these lines are: inkyParent * nonInkyParent *
Where "*" is the name of an actor, it will do no harm to leave these lines in, as IK was completely disabled by deleting the stuff from the 'figure' section, but if you want to do a really thorough clean up, you can delete these lines also. P.S. DarkEdge already said it, but as I had already written this before I saw his post, I might as well post it.
Les is always very thorough and also very correct - but I dont have a prob doing what Phil C said, in the Pose room, and also you wil want to save the figure to your runtime after you have delted the IK chain lines in the hierarchy editor
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
http://www.renderosity.com/homepage.php?page=3&userid=580115
Is there any way to actually remove IK from a cr2 without messing anything up?
I don`t just want to switch it off (it is clothing).
