Mon, Feb 3, 8:06 AM CST
Subject: Installing V4.2
kanaina ( ) posted Mon, 06 September 2010 at 8:34 PM · edited Mon, 03 February 2025 at 8:05 AM
I installed the file so long ago that now I can't remember how.  When I try to open the zip it says
it must be installed to the poser executable file.   DRIVING ME NUTS!  No matter what I do it doesn't get past this message.  WHAT AM I FORGETTING?
Real simple terms.  Like step by step for someone pulling their hair out.
Just reinstalled a bunch on Windows 7
Raindroptheelf ( ) posted Mon, 06 September 2010 at 9:03 PM
 I am not sure why you have a zip file because V4.2 comes as exe.file from Daz3d.
Mabye you should re download the file , it should be in your Account / Itemized Order History.
Hope that helps.
hborre ( ) posted Mon, 06 September 2010 at 9:09 PM
Also, which Poser version are you using?
Lucifer_The_Dark ( ) posted Tue, 07 September 2010 at 2:18 AM
If you're using Poser Pro or PP2010 you'll have to create a fake Poser.exe in the main Poser folder, actually you can install V4.2 anywhere as long as the folder includes a fake Poser.exe, just create an empty text file & rename it Poser.exe.
Windows 7 64Bit
Poser Pro 2010 SR1
tlc ( ) posted Tue, 07 September 2010 at 4:32 AM
I'm in the same position as kanain, I have Poser 6 on Win XP Pro and I had V4.2 in an external runtime. Can't remeber, for the life of me, how I did it, though it wasn't totally successful as when I used her in Carrera it asked me where the morphs were when I loaded her in. Any ideas guys? thx.**
Create Poser Mats for free in DS3
Rance01 ( ) posted Tue, 07 September 2010 at 7:03 AM · edited Tue, 07 September 2010 at 7:05 AM
For V4 I think it might be best to do a fresh install.  Create a dummy folder and inside that create a new test file: New Text Document.txt.  Rename that file Poser.exe.  Install V4 with all of her other packages.  Morph ++, etc.  Then you can move the contents of the dummy folders into your Poser - whatever version -  Runtimes.
Be certain to maintain the folder structures and keep all the files in relative path statements.
For future re-installs you may want to back up the dummy Runtime to a CD-ROM or backup folder and keep those original files.  That way you won't have to face the DAZ installers again.
Best Wishes,
Rªnce
Raindroptheelf ( ) posted Tue, 07 September 2010 at 9:56 AM
 If you want to Install V4 into an external Runtime you need to use the * Daz Studio * option when you run the installer exe. that way you can choose any location for the installation.
Hope that helped
tlc ( ) posted Tue, 07 September 2010 at 10:13 AM
This was my plan but over at DAZ I have seen warnings about HAVING to install into Poser 6's "home" Runtime.
So I have the external Runtime with the fake poser.exe in it and then just install, using the Daz Studio option,  V4, morphs++ etc to that runtime and everything will work okay?
Also, as A4, G4 and S4 are now free, do they have to go into the same runtime as V4?
Raindroptheelf ( ) posted Tue, 07 September 2010 at 10:19 AM
 Well it is always better to install those MAIN Daz Figurs in the original Poser Runtime , that is what they say BUT you can put each of those characters in there own Runtimes and they will work fine.
I have mine all in their own Runtimes.
Propblems will occur if you have for example your V4.2 in more than just one Runtime installed.
Same with the other Characters.
Jules53757 ( ) posted Tue, 07 September 2010 at 11:28 AM
With Poser 6 you have to move the libraries!DAZ folder into your main Runtime, thats all.
Ulli
tlc ( ) posted Wed, 08 September 2010 at 6:35 AM
thx guys, she works a treat in P6 and Carrera :) One last question, if/when there are updates should I move the !DAZ folder back to the ext. runtime updte and then move it back or is there an easier way?
