Benney nails it, but watch out for the eyes. They often don't come over to Bryce properly.
There is a way, not using DAZ Studio, but depending on who you ask, it's more difficult. With all the problems that some people encounter using the bridge from DAZ Studio to Bryce, I do it this way as a matter of habit.
1. In Poser: File->Export-> Wavefront OBJ.
If you plan to do this again, why not save all your textures (body, head, eyelash/eyebrows, hair, etc.) as Bryce materials. Then next time you import the figure, simply select the body and choose the saved texture, then the head and apply the texture, then the eyelashes and apply that texture, etc.
The eyes 'problem' message above - Poser sometimes has an 'outer layer' for the eyes, which turns up opaque when imported into Bryce. Shift+mouse click will list all the group areas under the mouse. You'll need to select the outer layer, and use a glass mat, usually the most transparent one.
Heretical method - create a good background in Bryce. Note light angles, light color, etc. Save as a jpg, go into Poser, and Import it as a background picture. It's what I do....
signed - 'Frequent visitor to the comfy chair...;)
@Pakled.
I import my figures into an empty Bryce scene, ungroup, then use the Tab button on the keyboard to step through every object individually. I get all my materials set and regroup the figure.
Next, go into the attriibutes and name the character something like vickisitting instead of group1. I save the character and the bryce scene in my bryce work folder usually as the same name" Vickisitting" whatever.
Now select the vickisitting character in the bryce scene. Press the Ctrl and the C buttons on the keyboard to copy the character. Go to the disappearing menu at the top of Bryce. Click on file and pull down. The bottom of the pull down menu should have the names of the last four bryce scenes you worked on. Click on the name of the scene you want to paste the character into. Bryce will ask if you want to save changes you made in vickisitting.You should just have saved but it hurts nothing to say yes and it could save the last hour and a half you just spent fiddling with vicki's translashes.
Your new scene should open up. Press the Ctrl and V keys together. The group vickisitting should appear as long as you didn't close Bryce.
Scale and position your character into the scene. Save the changes to the main bryce composition. When I work I like to number the files name01, name02, etc. Poser files with hard bends can cause clothing to poke into the nude figure. The render can start crashing when these meshes overlap and penetrate each other. Number the filenames so you can go back to the previous version and try again when you make major changes to the scene.
Attached Link: Grouper...
If you don't wanna Use DS to export/import you can use Grouper after you have exported the .obj and it will do all the textures searching and gathering... But will not deal with transparencies... It is a very nice little tool...
Vir sapit qui pauca loquitur.
I have a poser charcter that I would like to export form Poser 7 and import in to Bryce 6.0.1 -- how do I due this keeping all the items in tack with the hair color and skin color and so forth.
Thank you!
