Sat, Jan 25, 9:47 PM CST
Subject: Vue Infinite PLE & Poser Pro 2010 (is there an update?)
StealthWorks ( ) posted Tue, 14 September 2010 at 3:49 PM · edited Sun, 19 January 2025 at 4:11 AM
 I recently bought Poser Pro 2010 and was interested in trying to import a figure from Poser Pro 2010 into Vue Infinite PLE edition. However, when I try to configure Poser import from the Vue preferences it only lists up to Poser 8. Are there any updates to PLE that fixes this? When I go to the updates section in Vue you have to enter serial numbers etc. but PLE doesn't have any of these!
Any help greatly appreciated
Thanks
bruno021 ( ) posted Tue, 14 September 2010 at 6:11 PM
I doubt this will be implemented with Vue9 coming along. You might have to wait fo the Vue9 PLE, should be out in 3 months if e-on keeps the 6 month release  cycle...
Peggy_Walters ( ) posted Tue, 14 September 2010 at 9:31 PM
Pretty sure if you configure Vue for Poser 8 it will work for Poser Pro 2010 too.
LVS - Where Learning is Fun!
bruno021 ( ) posted Wed, 15 September 2010 at 3:33 AM
There will be problems Peggy, because Vue will look for geometries and textures in the Poser 8 folder, I think I read something about it in this forum. Worth a search.
sirrick ( ) posted Wed, 15 September 2010 at 4:08 PM
I'm not sure about Vue PLE, but in Vue 7 Infinite one of the options is "Poser Pro".  I'm using PP2010 without a problem.
StealthWorks ( ) posted Thu, 16 September 2010 at 4:25 PM
 Thanks for all your responses. Its a shame it doesn't support it but, I have a copy of Poser 7 so maybe I'll reinstall that.
Thanks everyone
Michael314 ( ) posted Sat, 02 October 2010 at 4:21 AM
Hello,
I just ran across the same problem. I just selected "Poser 8", but gave the path of PoserPro 2010 (64 bit). A couple of quick tests with some static scenes worked.
I used the 64 bit current (8.5) PLE version.
Best regards,
   Michael
