Thu, Feb 13, 7:07 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
Subject: BB's inverse square falloff shader?
Mark@poser ( ) posted Fri, 17 September 2010 at 11:55 AM ยท edited Thu, 13 February 2025 at 6:38 AM
I don't have P8 yet, so where can I get "BB's inverse square falloff shader" for Poser lights? I don't see it on his web site. I did a search on this forum and saw it referenced in a number of threads, but perhaps I did not look back far enough.
Thanks
Mark
IsaoShi ( ) posted Fri, 17 September 2010 at 1:54 PM
file_459300.txt
I'm not sure where I put BB's original shader, but here is my modified version, freshly saved as an umcompressed (mt5) material file from an old scene I did in Poser Pro. You need to change the file extension from .txt to .mt5 and save it somewhere in your library materials folder.
I've arranged the parameters down the left side... x, y, z position of the light (in inches!). Ignore the existing numbers in those nodes, they are just where the light was in my scene. Above the position parameters is the distance setting (the distance from the light source at which the intensity is equal to that set in the light's base node). You can adjust both the distance and the base intensity as required.
I also added a cheat parameter at the bottom, to adjust the fall-off up or down from true inverse square. You can just leave that at 100 percent.
It should work fine, but do ask if you run into any problems with it...
Mark@poser ( ) posted Fri, 17 September 2010 at 4:16 PM
Okay thanks. I'll try it out and see how it works.
