Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Feb 17 3:50 pm)
that looks fabulous!!!!
I aim to update it about once a month. Oh, and it's free!
Regards, Tom
Quote - Hi Cherokee69,
You make me feel good.
I really put my all into these products of mine and it makes it all worth the effort when I see comments like yours. :-)
Thank you!
I was not going to post many more images of this product until it is complete but here is a view of the dog legged alley that I just started to focus on. It runs around the six story parking garage. Complete with an adjustable water level on the puddles.
Everything you see is included and more on the way.
I just have to get it out of my head somehow. :-)
Hope you like this view as well. :-)~Regards, Tom
Tom,
That looks wonderful. There is only one thing I see that doesn't look right. It's to texture on the trash can top. It looks like you used the same texture on it you used on the can body. The "ribbing" effect for the can just doesn't look right on the lid.
Interesting. I live in Chicago, and although maybe not the mid-west, it is close to it. :)
Actually, i can't say I have never seen a brick paved alley, just never a red brick paved alley. I guess it is possible it was red brick when first paved, but usually it is a dark brown or even black brick. Most of the alleys here are asphalt under all the dirt and crud. Just my thoughts.
In the end, you should go with your vision. After all, it is what makes your sets worth it!
John
Wow. I only live about 50 miles across the lake from you.
I am glad you said that as when ever I try to bend my designs in a different direction it takes the fun out of it..
Keep in mind I set the UVW mapping to turn 45 degrees so if you apply a different texture it should fit in a 3 foot square on a 45 degree angle. Here is the brick texture I used for the alley to give you an idea what you would have to work with.
You could also color the brick texture in a paint program and make it darker.
Thanks a lot for the feed back.
Tom
Where I live here in North Carolina, in the early years of the town, the streets were dirt. The first paving was brick. In later years it was paved over with asphalt. Now, when they do any street repairs, they uncover the original brick but it gets paved over when the work in completed. There are a couple of streets that they have taken everything up down the the dirt and repaved with brick.
So I can see using brick isn't out of the ordinary. Brick streets isn't something that alot of people see too much of in the States. So, use the brick texture. If people want something else, it should be pretty easy to change.
My intent on this set of nine city blocks is to build a few loose items that can be used in the other sets. Such as the safety cones, the traffic control saw horses, an old tire, trash cans etc.. Different models with each set.
This set will be on sale as well, like I always do when releasing a new product. :-)
Here is a look at the dog legged alley that encompasses two sides of the six story parking garage, that has a full interior complete with two way ramps, and a valet office.
There is even an arched bridge above this view that connects the Washington Apts. to the parking garage.
I changed the texture on the brick to a square repeating brick so you can change the texture to suit your needs, just apply your own image to the brick. The size of the UVW mapping is 112 inches by 112 inches so adjust your image accordingly. That means that you want a texture that in the real world covers 112 inches square.
I also turned the mapping back to square to the world.
There are three barrel kinds, two of which you can see in this image.
The alley starts on one street, turns 90 degrees and exits on another street.
I am even giving you control over the water level in the puddles on the brick. The higher you move the water the more of the sunken down brick gets covered. The fire escape ladder will move as well.
And the list goes on.
Hope you like it so much you buy three of them. :-)
Regards, Tom
Tom,
Just bought the first set and I just am amazed at how well it renders in Poser. With all the stuff in it, I thought for sure it would bog Poser down some but it doesn't. Renders pretty fast and it really looks good.
Now, with the second set fit in with the first one? And, how about Fisher's Warehouse and Coleman's Creates? Will those work with it at well?
That second set it looking awesome. Can't wait for it to get to the store. Keep up the great work.
well while you are modelling is it possible to make a mat pose with the set to turn the brick street into a modern looking street?
Love esther
Thanks guys,
Cherokee69 yes those sets are available for Poser as well.
Glad you like the City block.
Estherau,
I will think about it.
As I have gone to a square UVW mapping that is square to the world you could simply add your own texture and adjust the tiling your self.
The problem with me adding additional textures is there about a million different ones to choose from.
So most likely I will not include any more textures for the alley. Sorry to disappoint you. If you buy the set and want to PM me I could possibly walk you through changing the material with your square texture and make it work.
Once again guys thanks for the feed back.
it truly does help me.
regards, Tom
Quote - The scale appears to be close, but not exact. it would take a lot of tweaking to get it looking right; however i think it could be done. I didn't try for any great length of time. Just tried a quick one. Fishers Warehouse does dwarf the size of the blocks; but the scale is close.
Yeah, that's true but not by much. I just loaded all of them in Poser and Poser just zipped through rendering the whole thing. All I did was just move them around so they weren't all loaded in the same spot.
Tom, as good as these are and how well they render and look, you going to make and entire (well, almost) city.....block by block?
Quote - Tom,
What I meant was will Fisher's Warehouse and Coleman's Creates work with the 2 City Blocks or are they a different scale?
No they will not work together as the city block set is smaller for the sake of polygon counts.
They were both exported out of 3D Studio Max at the same scale. They were modeled at real world sizes.
Sometimes I make the floor to floor height different for effect.
The city block set is designed around square city blocks that are a certain dimension. of 301.979 feet square. Both directions.
That is so you can move any one of the nine sets to the nine locations and rotate them up to four times for a combination of somewhere around 300 plus.
Please keep in mind these are not architectural blueprints so some creative license was taken on my part.
If you want me to build models that are that kind of accuracy and that amount of detail then they would cost around 10 to 25 thousand dollars and would be in the millions of polygons and would kill most computers. These models are an entire city block and do not exceed 100,000 polygons with the exception of Fishers Warehousing.
Also there is the issue of Poser not being an exact program when it comes to import. I picked .01 as the export scale from Max but that is because I can only export at two decimal places instead of 5 or 6 that it would take to get it perfect.
So on a model of this size the scale might be off by a foot or two overall of the whole nine blocks.
Hope this was a good explanation of the issues at hand.
Thanks for all the feedback guys.
Now back to modeling City Block set two.
regards, Tom
P.S. Yes I am modeling nine city blocks of buildings.
I guess that qualifies me for a trip to the mental institution when I get done. Just to rest up mind you. :-)
Attached Link: Link to E-On softwares site.
![file_459197.jpg](https://live.cdn.renderosity.com/forum/threads/2811058/file_459197.jpg)
Hi guys, Here is a small look at what is coming next. yes that is a 6 story parking garage, complete with elevator. Just add the guys who wreck your car when they park for you. There is also a dog legged alley for those dark lit night time scenes. Many other details that you can not see here but more on that later. Have not gotten to the fine details yet but this gives you and idea of where I am going with this set. Movie Sets, City Block Two for Poser Movie Sets, City Block Two for Vue Comments are as always welcome. Regards, TomClick the image for a 1920 x 1080 view.
Thanks for looking
