Mon, Jan 13, 10:28 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: Object black in Render
uncle808us ( ) posted Mon, 27 September 2010 at 1:14 PM · edited Thu, 09 January 2025 at 9:52 AM
In the Preview in Poser 7 Mac my object shows correctly but when I render it is totally black. Never had this happen before. Any ideas????
MacBook Pro OSX El Capitan Ver 10.11.6
lesbentley ( ) posted Mon, 27 September 2010 at 1:17 PM · edited Mon, 27 September 2010 at 1:18 PM
With the object selected, could you post a screen shot of the material room advanced tab? It might give us a clue.
Also, check that the normals are forwards.
colorcurvature ( ) posted Mon, 27 September 2010 at 1:29 PM
is it the first/only thing that you loaded into the scene?
uncle808us ( ) posted Mon, 27 September 2010 at 1:36 PM
> Quote - With the object selected, could you post a screen shot of the material room advanced tab? It might give us a clue. > > Also, check that the normals are forwards.
Here you go.
uncle808us ( ) posted Mon, 27 September 2010 at 1:37 PM
Quote - is it the first/only thing that you loaded into the scene?
Yes only thing in the scene. Also It works right in Poser 8.
uncle808us ( ) posted Mon, 27 September 2010 at 1:49 PM
If I put a primitive like a sphere then the milk carton renders correctly. What is up?
uncle808us ( ) posted Mon, 27 September 2010 at 2:06 PM
Same as in Poser 8 if I have another obj it renders OK but remove the object or figure and render is once again black.
Miss Nancy ( ) posted Mon, 27 September 2010 at 2:25 PM
it's a known bug.  small objects exhibit self-shadowing by a square shadow map.
incr. obj. size to figure size and it renders properly.  or add second obj to increase scene size.
in addition, uncheck "refl. lite mult" - bad poser 4 setting.
uncle808us ( ) posted Mon, 27 September 2010 at 2:29 PM
Will do....
uncle808us ( ) posted Mon, 27 September 2010 at 2:52 PM
Did that and it fixed the problem. But it screws my proportions.
SamTherapy ( ) posted Mon, 27 September 2010 at 4:11 PM
Put another object in the scene, such as the one sided square.  Keep it out of the camera view and your prop should render ok.
uncle808us ( ) posted Mon, 27 September 2010 at 4:15 PM
Yes that works.
SamTherapy ( ) posted Mon, 27 September 2010 at 5:03 PM
There's your solution.  Not elegant but at least it works.
uncle808us ( ) posted Mon, 27 September 2010 at 5:41 PM
Thanks everyone
