Fri, Nov 22, 4:16 PM CST
Subject: How do I USE the morph tool
perpetuavelouria ( ) posted Fri, 01 October 2010 at 4:23 AM · edited Fri, 22 November 2024 at 4:08 PM
HI
Now, I caapitalised the word USE in the title, because, I understand how the tool works, how to set up the various settings etc....
But what really gets me frustrated is that 9 times out of ten when I have selected what (or who) I want to morph, the tool selects an object behind the figure I'm working on instead!
Is the only way around this to load up the figure on its own in a new scene, make and save the morph and then reload the scene I want the morph for? That seems a bit long-winded.
whipporwill ( ) posted Fri, 01 October 2010 at 4:47 AM
I've had good luck by right clicking on what I want to morph and selecting it  from the little drop down menu that pops up before I go to use the tool. Also I always double check and make sure that in the figures/props drop down menus the item I want to be working on is what's actually selected, as Poser seems to select whatever it's in the mood to select half of the time, lol! hope that helps!
Fugazi1968 ( ) posted Fri, 01 October 2010 at 5:48 AM
Once you have your model/prop selected keep the shift key held down while using the morph tool.  It locks the selection so you don't accidentally pick a different object while you are morphing.
John
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
perpetuavelouria ( ) posted Fri, 01 October 2010 at 6:09 AM
Quote - Once you have your model/prop selected keep the shift key held down while using the morph tool.  It locks the selection so you don't accidentally pick a different object while you are morphing.
John
BRilliant! THanks!
hborre ( ) posted Fri, 01 October 2010 at 10:51 AM
And I second that technique.  The perfect solution to isolate the mesh you are working on.
