Sat, Dec 28, 12:08 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 9:24 pm)
Subject: Help, frustrated!!! can't get dark shadows on v4, she glows in the dark...
muromedia ( ) posted Tue, 05 October 2010 at 1:07 PM · edited Fri, 27 December 2024 at 11:48 PM
Hi,
Decided to get back into poser after a few years of absence. So, forgive me if this question is obvious to most, but I'm stuck. I'm trying to get dark shadows to appear on v4 (default daz textures). And no matter what I do, she's always glowing in the dark regardless if there is no light on her.
Is there a way to fix this??
By the way poser pro 2010, here's a sample of what I'm talking about. Everything around her is black (no light, parts of her body should also be 100% black, but they are not!!!)
Thanks for your help
Nick
LaurieA ( ) posted Tue, 05 October 2010 at 1:17 PM · edited Tue, 05 October 2010 at 1:17 PM
Check the material room. There's most likely ambient or translucence or alternate diffuse in the skin mats.
muromedia ( ) posted Tue, 05 October 2010 at 1:41 PM
Thanks,
That did some to solve the problem, but that also begs the question, is there a python script that can set all these values to 0 in poser 2010?
I remember that poser 6 had an option to turn of advanced material shaders or something like that. I don't see an equivalent in poser pro,which means i have to set each node off one by one ;-(
Nick
SamTherapy ( ) posted Tue, 05 October 2010 at 2:28 PM
Well, you discovered the default shader supplied with V4 is absolute bobbins, so now your next step is to get a replacement.  IMO, you should take a look at BagginsBill's VSS.  A search on the forum - it may even be in the list of nodes and shader stuff at the top - should unearth it.
I can't answer your PP 2010 query, unfortunately.
RobynsVeil ( ) posted Tue, 05 October 2010 at 2:30 PM
If those are the Daz default shaders, you might try the skin shader that came with the latest sortie of VSS (PR3, I believe). Just do a search on user Bagginsbill (who developed VSS, which is a shader management tool: it distributes a given shader over multiple material zones) and have a look at his signature. This will link you to all sorts of fine tools he's developed for the Poser community, including VSS.
Metaphor of Chooks
muromedia ( ) posted Tue, 05 October 2010 at 3:40 PM
VSS Rocks!!!!!
Does exactly what i need.
Thanks
Nick
hborre ( ) posted Tue, 05 October 2010 at 8:39 PM
Did anyone mention that the gamma correction in the VSS Skin Template needs to be set at 1 when used with PoserPro and PoserPro 2010?
muromedia ( ) posted Tue, 05 October 2010 at 9:16 PM
 No, but i did manage to find that on one of the threads on on IDL and VSS. I had to set the gamma to 1.3 and sss = 0
thanks
RobynsVeil ( ) posted Wed, 06 October 2010 at 1:19 AM
You're welcome, Nick... and thanks for pointing that out, HBorre. :blushing:
Metaphor of Chooks
