the clothroom uses obj props not cr2's
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
The cloth room works nicely with raw OBJ files. I use it that way all the time.
You may not be able to wrap the net entirely around a human, but you could get
it partway around.
Place the human horizontal, with the net horizontal over the human but not touching.
Scale the net up or down and move it around until you can tell that it will
drape over the right parts of the human.
(This is the hard part, and will probably take several complete tries to get it right.)
Set the timeline for 30 frames or more.
Select the net; get into the cloth room; Clothify the net.
In the "collide against" dialog, pick the parts of the human that need to be
surrounded by the net.
Start the simulation.
When done, get out of the cloth room and find the frame that looks best.
With the net still selected, hit Object : Spawn Morph Target, and give the
morph a name.
Save the net as a Prop. It will then have a morph that pulls it into the
position you made with the cloth room.
My python page
My ShareCG freebies
*the clothroom uses obj props not cr2's
*That's not completely correct, you can use a body part of a CR2 as a dynamic object. It's called a "hybrid" CR2. I've made two chair's who use this technic: a beachchair and a folding chair. You can download them from my freebies and follow the instructions to see how it works.
Best regards,
Bopper.
![file_460363.jpg](https://live.cdn.renderosity.com/forum/threads/2813492/file_460363.jpg)
Pappy411 told me I could use the cloth room to be able to wrap his net object around an M4 or V4 figure?! It is an object though, not a figure. Can I do that? Use the cloth room to wrap the net around V4 or M4 V4 in a romatic swept way type setting? The net comes with two basic morphs.
