Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 7:18 pm)
Tattoos
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3093841
Decals
http://www.runtimedna.com/forum/showthread.php?31709-Dual-Materials-with-Stencils
And a little more explanation of how the Blender node works:
http://www.runtimedna.com/forum/showthread.php?39937-Blender-Node-Question
Eric Peacock
dracoselene@gmail.com
Blue
Dragon Creations
<a href="http://zazzle.com/brianadragon">My Stuff
at Zazzle.com
Attached Link: Tattooed Alex
Lower the blending and you get more of a fade on the tattoo. You can even link entire chains of tattoos together. I strung together 4 or 5 different tattoos to get this.**
Eric Peacock
Blue
Dragon Creations
at Zazzle.com
Quote - Tattoos
Decals
This should all be done after using VSS, correct?
I'm eagerly anticipating any kind of answer that BB might have, it took me a week or two to figure out how (where in the node soup rather) to put my tattoos into a shader made with VSS.
Eric Peacock
Blue
Dragon Creations
at Zazzle.com
Quote - > Quote - Tattoos
Decals
Well... I'd actually set up a set of rules to apply the decal from VSS itself - I'd incorporate all of it into the Template_Skin.
But that would be hard for you guys - it is node spaghetti for sure. I don't build the nodes by hand - I use matmatic.
A tattoo template skin was one of the things I always meant to publish. Can't do it right now.
Is it possible with Poser's Material room, some kind of shader node, whatever, to apply tattoos or decals over a texture?
I don't mean to apply a whole new texture with a tattoo painted on it, but rather to be able to apply just a tattoo or decal to any skin surface.
For example, if I paint a tattoo of some sort and want it on a light skinned figure's Body map I would paint it on that texture. But if I wanted to have it on a dark skinned figure I would have to redo the entire thing, painting it on the dark skin map.
So obviously it would be easier to just paint it once and be able to make a mat pose file to be able to apply it to any figure without having to redo the entire texture.
I'm thinking some sort of alpha mask, but I have no idea if it's possible in Poser. It seems to me that would entail having to have two Body textures applied at the same time. Then again, I have no idea if there is some way, because I simply don't know, which is why I'm asking. ;-)
