Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 18 7:39 am)
Sounds like the column got stuck at being a really large size up and down. I tried to replicate your issue (to an extent) by intentionally increasing the size of my parameter dial bar past the taskbar, and I ended up having the same issue as you, where I was unable to reach dials past a certain point.
What I tried as a workaround was this. I started dragging the parameter dial bar upwards a bit (it won't let you do it very far) but when you do this, it slides that window up, and then snaps back down. If you continue to do this, you can eventually bring the bottom of the parameter dial bar above your taskbar.
Of course, you could alternatively just set your screen resolution for something crazy high temporarily, and resize the bar, and change back to your normal resolution.
Currently using Poser Pro 2012 (Display Units = feet)
AMD Phenom II 3.2ghz (6 cores)
8gb RAM
Windows 10 Pro 64bit
I am not sure if I am understanding the cause... I suspect the issue is the Tool Bar is taller than you window, so scrolling will not bring up the bottom of the Dials. I had this happen with Access once and had to increase the Screen Resolution so I could resize the window up and down.
For Poser, Resetting Preferences would fix this or Launching to Factory State should as well.
If the Window is growing on its own, contact Support with the details of how to reproduce that. It should not grow on its own.
ratscloset
aka John
If you're working with different screen sizes, use the UI Dots to save the Poser interface configuration for the different resolutions.
My visual indexes of Poser
content are at http://www.sharecg.com/pf/rgagnon
