Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
If you have render gamma correction enabled, you have to set the gamma on transmaps to 1.
I don't have P7 to compare and see what you mean that now the hair is more thin/whispy than before. I'm guessing that the interpretation of hair has changed.
Nevertheless, even if the actual value of hair thickness is interpreted differently, it is still adjustable. Have you tried making it thicker?
Another thing that may have changed is the result of "opaque in shadow", an option on the Hair node in the material room. And the notion of what is "in shadow" is probably different than it used to be. Since hair rendering is much faster now, I have to believe the rendering algorithm has changed, which means you may have to adjust things. It could mean there is no way to adjust it to appear the same as it used to be, but I doubt that.
Attached Link: http://renderosity.com/mod/forumpro/showthread.php?message_id=3559731&ebot_calc_page#message_3559731
Disable texture filtering for the textures that are plugged into the dynamic hair.Cranking root and tip width up a bit won't hurt either.
Ah, I see, That makes sense. I usually use dynamic hair only with human scullcaps, but with furry rodents and other animals I can see why you use a texture. I'm not sure the OP was referring to that. I've used a lot of dynamic hair, most made by Adorana, and I came to same conclusion that poser8 and poserpro2010 make look the hair very thin. I got better results by increasing the hair density of every hairgroup in the hair room. I also experienced that plugging a diffuse shader with a very dark haircolor in the ambient, next to a hair shader in the alternative diffuse shader, give very good results. The rendering of dynamic hair in poser8 and poserpro2010, in a combination with indirect lighting gives better and faster results than transmapped hair.
I only wish poser would have some tools to shape dynamic hair.
best regards,
Bopper.
Hello, I have been trying to render some hair in Poser Pro on the Lycanthropos figure and it renders fine and is actually quicker than in Poser 7 but everything is much thinner and it is whispier than I am used to and I am wondering if there is anything that I can do to make it render more like the one in Poser 7. I don't really use it except on this figure and I am a bit at a loss on how to get it to show like it should. Thanks.
