Mon, Dec 23, 1:18 PM CST
Subject: Fire in Vue
bernieloehn ( ) posted Mon, 01 November 2010 at 5:44 AM · edited Mon, 23 December 2024 at 12:50 PM
There is always again this problem of realistic looking fire in Vue.
What do you think about the fire in this picture, rendered in supirior mode, 72dpi?
The fire material is an eco-system. Please note: The picture and the mats and vob are made in Vue 8 Complete!
Bernie
Keep cool and fight for the right of others
to have a different opinion than you have!
;- ) Bernie
bernieloehn ( ) posted Mon, 01 November 2010 at 5:46 AM
Here comes the picture.
;- ) Bernie
bernieloehn ( ) posted Mon, 01 November 2010 at 5:49 AM
Attached Link: The campfire.vob
Please find here a link for the complete campfire.vob including the textures.
The vob is group of the objects and a point light.
;- ) Bernie
mstnicholas1965 ( ) posted Mon, 01 November 2010 at 9:55 AM
I love the glowing embers on the logs. The flames however are to solid. Fire is a plasma state of matter (part gas, part liquid) and so tends to be more ethereal. Good work though.
thefixer ( ) posted Mon, 01 November 2010 at 1:47 PM
I use Poser fire in Vue, looks much better and I will also use post for it too..
Injustice will be avenged.
Cofiwch Dryweryn.
FrankT ( ) posted Mon, 01 November 2010 at 2:45 PM
I actually use the flames from a DM prop usually.  Set the luminosity up a bit, add a point light et voila !
My Freebies
Buy stuff on RedBubble
tsquare ( ) posted Mon, 01 November 2010 at 7:12 PM
I had the same problem.
An example of a render I will most likely rework the fire in one day.
bernieloehn ( ) posted Tue, 02 November 2010 at 3:44 AM
@ tsquare: Oh, I think your fire looks much better - not that X-mas kitchy like mine - LOL!
;- ) Bernie
zonkerman ( ) posted Tue, 02 November 2010 at 8:00 AM
Might want to consider using photoshop to blend a combination of fire layers such the following product:
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=66610&keyword=flames
Then output it as a .png with a transparent background.  Then import it into Vue onto an alpha plane so the flames stand out with the transparent background allowing you to still see things somewhat behind them.
sirenia ( ) posted Tue, 02 November 2010 at 2:11 PM
The best i ever achieved with fire in Vue is by using an alpha plane that projects a fire. I started with placing some rocks in a circle, adding lots of thin branches in the middle and than placing the alpha plane on it.
I also added a lot of cubes (!) which i used for sparks that are flying above the fire (as you would see on a real fire) and i thinks it adds a lot of reality to it.
This image whas never finished and i think i can search for a better flame to project on the alpha plane, but the reason i post the image is to contribute to this forum to let us all build a better fire :-)
Sorry for the low quality of the render (preview render)
Oh almost forgot to mention that i made the materials glow on the cubes :-)
Society failed to tolerate me...
... and i have failed to tolerate society
sirenia ( ) posted Tue, 02 November 2010 at 2:15 PM
tsquare ( ) posted Tue, 02 November 2010 at 10:16 PM
Thanks Bernie!
ooo... I like that Sirenia!
thefixer ( ) posted Wed, 03 November 2010 at 3:26 AM
That looks really good sirenia, nice job..
Cofiwch Dryweryn.
silverblade33 ( ) posted Wed, 03 November 2010 at 4:30 PM · edited Wed, 03 November 2010 at 4:32 PM
This pic:
http://www.renderosity.com/mod/gallery/index.php?image_id=1778138&user_id=7541&np&np
I made using an Alpha plane for the fire, with a light source near it, custom set up so it would work right (lot of tweaks need done ot get lights to work best at times)
The flames used a "fire" .psd I'd bought, think from Rendo store ages ago, one of a pack of many fire images with transparency,needed to tweak it though as the transparency wasn't set right (can be done in Photoshop, or using a filter in Vue itself to boost the clipping of the transparency)
I made a custom material for the sword to make it look "molten" on the edges
a mixed material, using original sword blade (which I'd tweaked anyway as I usually do wiith Poser imports)
then, I made a UV map of the sword blade, taking that, I made a mask for driving the distribution function of the Mixed Material, so the edge would have the firey material I made.
I.E, the mask was a black and white image, black being the parts of the blade I wished ot be molten.
Also, you can use Wabe's "Fire Bugs" which is an ecosystem fire effect, or Monsoon's "Fire" pack, both of which I have and are excellent :)
it all depends on what you wish to ACHIEVE, as "fire" can be many things. I've also made fire in postwork, using plugins in Photoshop
Eye Candy has a fire filter, I have a free version of 3.1 but can't remember if it's on that, but I bought Textures, Nature and..oh forget name of other pack they have, "Fire" is in one of them...alas my art PC is dead so I can't check, sigh
Alternatively you can try "Particle Illusion", again I have it and it's VERY damn good :)
AND, you could make such fire effects using Photoshop or Particle Illusion, as a .psd or .png or .tif, and import into Vue as alpha planes! ;)
There's also a "fire" video in the tutirials of Vue, or was, that I've often used as well on a "billboard".
My work though is usually "stlyistic", not "photorealism". Can't explain it easily but I'm less concerned with 100% realism, mroe about "looking good for my taste/style"
My first attempt at fire in 3D, 10 years?? ago or so in Bryce, using a custom bryce material I made
http://www.silverblades-suitcase.com/artofadreamer/3d/orcsfortfireball.jpg
Few years later, made this in postwork, Paint Shop Pro and a "photoshop" plugin, then used hand painting etc to work it, I painted in the ogre's skirt and cloak, fyi ;) lol barley knew how ot work Poser back then
http://www.silverblades-suitcase.com/artofadreamer/3d/ogre1.jpg
Bit later, this fire elemental is again a custom bryce material
http://www.silverblades-suitcase.com/artofadreamer/3d_2/redorious3.jpg
First fiery material I made in Vue
http://www.silverblades-suitcase.com/vue1/the_duel1a.jpg
First "proper" fire I did in Vue, using alpha plane:
http://www.silverblades-suitcase.com/vue1/alfred_6.jpg
http://www.silverblades-suitcase.com/vue1/alfred_hdr1.jpg
Suign a "fire" mat in Bryce years ago, I changed it to make plasma...I dod the sma ein Vue, now for , scifi and fantasy effects
http://www.silverblades-suitcase.com/artofadreamer/3d/mech2_large.jpg
Cue cene with plasma
http://www.silverblades-suitcase.com/vue1/gunwing6.jpg
this isn't fire but is shown as examples, but using Brushes photoshop and Layer Styles/effects you cna make fiery/smoke effects
http://www.silverblades-suitcase.com/fantasy_2009/call_of_yeenoghu.jpg
http://www.silverblades-suitcase.com/fantasy_2010/forest_war_goblin_shaman2.jpg
Voronoi functions cna be used ot make nice fire
tsquare ( ) posted Tue, 16 November 2010 at 3:28 PM
Wow,  a bunch of nice links!  Thanks!
silverblade33 ( ) posted Wed, 17 November 2010 at 6:20 AM
Tsquare,
my pleasure! :)
and sorry about the typos, sigh.
