Mon, Dec 23, 10:46 AM CST
Subject: ATI HD 5770 Windows 7 64bit Poser Pro
Markus_2000 ( ) posted Fri, 12 November 2010 at 8:56 AM · edited Mon, 02 December 2024 at 4:35 PM
I upgrade my videocard from an Nvidia to ATI and now when I go into the Material Room to change textures there is a terrible lag when selecting materials to edit.
When I change the preview type from OpenGL to SreeD the delay is gone but the screen is very jerky in SreeD.
Anyone know a fix for this?
I'm using the latest drivers.
ranman38 ( ) posted Fri, 12 November 2010 at 10:12 AM
I feel your pain, but have no solution. I have an ATI hd 4600 same deal.
Darboshanski ( ) posted Sat, 13 November 2010 at 11:55 AM
ATI has often been noted for a few OpenGL issues but I thought they pretty much worked that out. I do know that and ATI graphics cards don't play well with Vue but I thought they did okay fr poser. When you switched cards did you run a program like driver sweeper to seek out and destroy all traces of the Nvidia drivers? Also is your latest update for your driver from ATI or is it from a windows 7 update?
My Facebook Page
Markus_2000 ( ) posted Sat, 13 November 2010 at 7:04 PM
Latest Catalyst drivers 10.10.
Tried driver sweeper.
OpenGl works fine as long as I don't go into the Material Room.
Darboshanski ( ) posted Sat, 13 November 2010 at 8:00 PM
Quote - Latest Catalyst drivers 10.10.
Interesting yet....not I will continue to say Poser Pro 2010 has OpenGL issues that were not caught. I don't have an ATI card but experience little issues similar to yours except mine has to do with cameras. Sometimes when Windows 7 has one of their little updates it seems to corrupt some video card drivers. I am sorry I couldn't help more I hope some one can give you answers to clear up an irritating problem.
My Facebook Page
FightingWolf ( ) posted Sun, 14 November 2010 at 7:57 PM
I have and ATI graphics card and I just downloaded and installed the latestes drivers from their site. There's another thread somewhere dealing with ATI graphics card where I posted a link that will allow you to get the updated driver from the site.
Don't upgrade the driver from Windows 7 go to the actual site and download the graphics suite for your graphics card.  That should fix any problems.  If you have already done this then I don't know what to tell you.  I have Poser Pro 2010 and the upgraded graphic suite that I downloaded and installed from the site solved all of my ATI graphics problems that I know of as it relates to Poser Pro 3020 without the service releases.  I have yet to install the SR for Poser Pro.
ratscloset ( ) posted Tue, 16 November 2010 at 12:29 AM
Not sure if this will fix this issue.. This sounds like an old issue with older ATI Cards and the fix was to edit the Poser ini so
Preview_OGL_BBOXPICKING was set to 1
Contact Support with your details and the results of this so the Project Team can get with ATI to address this issue again.
Thanks
ratscloset
aka John
BrainGuy63 ( ) posted Tue, 16 November 2010 at 3:03 PM
Interesting- I took a look at this on a Win7 x64 AMD system with a Radeon HD3870 and the latest 10.10 drivers and didn't see a problem (Poser Pro 2010 11916, the SR1 version.) Was there anything specific in the scene that you were working on that might cause this problem, or does it happen with even really simple scenes (like the default?)
Markus_2000 ( ) posted Wed, 17 November 2010 at 8:19 AM · edited Wed, 17 November 2010 at 8:19 AM
I'm using Poser Pro not Poser Pro 2010.
Markus_2000 ( ) posted Wed, 17 November 2010 at 8:57 AM
I tested the it in Poser 7 and same issue.
The issue is only present when working with textures. Solid colors are no problem.
BrainGuy63 ( ) posted Wed, 17 November 2010 at 6:42 PM
That certainly makes a difference! Unfortunately since Pro 2010 is out now I wouldn't expect any further Pro updates beyond 7.0.4.220. As ratscloset points out there may be a setting that would help. If you do contact Tech Support they'll probably want to see your Poser.ini file to see what settings it's using.
Markus_2000 ( ) posted Thu, 18 November 2010 at 7:52 AM · edited Thu, 18 November 2010 at 7:53 AM
Went back to Nvidia and it's all good.
That was my first and last experience with an ATI card.
bagginsbill ( ) posted Fri, 19 November 2010 at 1:15 PM
I have the ATI HD 5770 on Windows-7 64-bit with Poser Pro 2010 - works perfectly. And that card is an absolute screamer for every game I've played - even MS Flight Simulator X set to every possible nutty extreme quality setting runs very fast.
You can't blame ATI for a problem with the old Poser Pro written 3 years ago.
Markus_2000 ( ) posted Fri, 19 November 2010 at 5:52 PM
I don't blame ATI but I've never had a problem with any of my Nvidia cards.
Markus_2000 ( ) posted Wed, 01 December 2010 at 9:49 AM
UPDATE!!!
Thanks to John at Smith Micro support the issue was resolvd by editing a file on my computer. My brother now has a new Nvidia card for Xmas and I have my Radeon working great.
THANKS JOHN!!!
