Tue, Jan 21, 2:42 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Subject: Have a problem with Y rotation on Mike4
FaeMoon ( ) posted Thu, 18 November 2010 at 9:04 PM · edited Sun, 19 January 2025 at 6:17 PM
I am trying to build a scene as a going away present for a coworker.  I have the morphs all done on the character and clothing.  I loaded some scenery in, and for some reason the y rotation has changed from turning Mike 4 around to moving him around in a large circle.
How do I get it to go back to the default?  I've closed Poser and also restarted my computer and that does nothing.  I'm searching through the manual, but I really don't know what I'm looking for.  I'm using Poser Pro 2010.
Any help is greatly appreciated.  I've done a ton of morphing on this character. :(
Delaney
jestmart ( ) posted Thu, 18 November 2010 at 9:38 PM
Somewhere along the line his point of origin has move.  It could have happened if any of the morphs are custom morphs athe mesh was moved in their creation.
FaeMoon ( ) posted Thu, 18 November 2010 at 9:39 PM · edited Thu, 18 November 2010 at 9:40 PM
But how do I change it back?  I've been using the ++ morphs and the dials and stuff, not the morphing tool.
geep ( ) posted Thu, 18 November 2010 at 9:45 PM
Attached Link: http://www.drgeep.com/p4/figcir/figcir.htm
See Page 6 in this tutorial (click the link above the image).
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
FaeMoon ( ) posted Thu, 18 November 2010 at 10:02 PM
That does reset it to the default 0, but when I try to rotate it again like turning around in place, he still moves in a big circle....
Good info though, and I'm glad to know about the alt click thing, that's a timesaver!
Any other ideas?  :)
chriscox ( ) posted Thu, 18 November 2010 at 10:36 PM
You may want to check the X and Z tans of the hip to make sure they are zero.
Rotating the Body while the X and/or Z trans for the hip are not zero can result in a figure rotating in a big circle
Chris Cox
FaeMoon ( ) posted Thu, 18 November 2010 at 10:46 PM
Quote - You may want to check the X and Z tans of the hip to make sure they are zero.
Oh wow.. thank you.. that seems to be working!!!
geep ( ) posted Fri, 19 November 2010 at 3:46 AM · edited Fri, 19 November 2010 at 3:49 AM
> Quote - > Quote - You may want to check the X and Z tans of the hip to make sure they are zero. > > > > Rotating the Body while the X and/or Z trans for the hip are not zero can result in a figure rotating in a big circle > >   > > Oh wow.. thank you.. that seems to be working!!!
Hi Delaney Anne,
"Reset The Hip"
Um, that was on Page 7 of the tut. 😄
cheers
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
FaeMoon ( ) posted Fri, 19 November 2010 at 11:08 AM
Quote - > Quote - > Quote - You may want to check the X and Z tans of the hip to make sure they are zero.
Hi Delaney Anne,
"Reset The Hip"
cheers
dr geep
Yeah, I saw that but didn't put two and two together, I guess.  Sometimes I get 5, or something.  lol  But thank you, I will be using lots of things in that tutorial.  You rock.  :)
Delaney
geep ( ) posted Fri, 19 November 2010 at 1:23 PM
Done there, been that .... No prob. 😄
cheers,
dr geep ... :o]
edited 10/5/2019
