Now it's really goofy. For a while, I would start Vue from scratch and I'd get my empty/non-functioning screen, and then when I clicked on File > New from inside Vue, I'd get my new one-sphere default screen. I tried this a couple of time with the same result.
However, now when I start Vue from scratch, I get the one-sphere default screen right from start-up so now it's working the way it's intended.
I'm wondering if I am to deduce from this that Vue is alive and with a will of its own. Scary, eh?
If it happens again, I'll try your remedy, TD, but I think I did the Run as Administrator-thing for Vue a long time ago, so I don't think that was it.
Good to hear you got it working now
For the record I add 4 extra cameras, change the main camera perspective and render size and widen the gadgets bar on the right side.
The only thing that doesn't stick for me is I check 'Render to Screen' before settingthe default, but I always have to go back and do that manually
Gill
OK, I think I solved my mystery. When I made the changes, Vue went right back to not working again. No personalized scene.
I discovered you have to have the box "Create empty scene on startup" checked after you personalize your scene and click the "Set default scene." I would have thought this one should be unchecked or else you'd get a default scene rather than your own personalized scene.
But I got it to work using the above method, however, like in Gill's case, "Render to screen" is the only option that doesn't stick.
I am wondering if anyone has tried to set up a Default Scene in the File > Options dialog box, and if so, does it work? I thought I'd get some input from others before I report it as a bug to e-on.
When I try to establish a default scene with a changed camera position and a simple sphere, I just get a blank one-pane Vue display with all the tools icons dimmed instead of the default 4-panes with the normal tools working .
Vue 9 Inf. Build #9005248, Windows 7 64-bit, GeForce GTX 260/PCI/SSE2 video card.
