Sat, Dec 28, 3:19 PM CST
Subject: Vue 8.5 crash
fleshoff ( ) posted Sat, 27 November 2010 at 4:41 PM · edited Sat, 28 December 2024 at 12:29 AM
Win7, Vue 8.5 standalone...I have a very complex scene with multiple animations. If I try to render it out in anything but 25 fps the animation render crashes. Doesn't matter resolution...any ideas?
Frame grab:
www.insectula.com
Facebook
ShawnDriscoll ( ) posted Sun, 28 November 2010 at 12:47 AM
Crashes on first frame?  After first frame?  Crashes during first second of animation if frame rendered is > 25?
fleshoff ( ) posted Sun, 28 November 2010 at 12:51 AM · edited Sun, 28 November 2010 at 12:53 AM
Crashes as soon as I hit render if not set at 25 fps. If I have it set at 25 fps it never crashes and renders fine.
*and this only happens with this particular animation.
www.insectula.com
Facebook
nruddock ( ) posted Sun, 28 November 2010 at 4:31 AM
Are you rendering to an image sequence or to some movie format ?
fleshoff ( ) posted Sun, 28 November 2010 at 9:04 AM
avi uncompressed. It usually works fine.
www.insectula.com
Facebook
nruddock ( ) posted Sun, 28 November 2010 at 10:26 AM
In that case can you render the problem frame as a single image without problems ?
fleshoff ( ) posted Sun, 28 November 2010 at 10:47 AM · edited Sun, 28 November 2010 at 10:51 AM
well there is no problem frame because it crashes as soon as I hit "render animation". I probably could render them out to single images but now that I'm 24 hours into a 100 hour render I hate to start over...I guess I'll see what happens.
I should probably be rendering out to image sequences anyways...I'm new to 3D and especially Vue (had it for about a week now) and I didn't know Vue had that option :(
www.insectula.com
Facebook
fleshoff ( ) posted Sun, 28 November 2010 at 11:10 AM · edited Sun, 28 November 2010 at 11:11 AM
I decided to kill the render and start over with image sequence...same issue... crashes immeadiatly when I try 24fps but not 25fps. So I'm rendering it out as an image sequence at 25 but at least now I can check on every frame and kill it if something is amiss.
Still perplexed by the 25fps issue, but may have something to do with the Poser animations I'm bringing in...I'll have to check and see if there is some issue with what frame rate Poser animations are created in.
www.insectula.com
Facebook
