Sat, Jan 11, 2:00 AM CST
Subject: Problem with render animation
Estruch ( ) posted Tue, 07 December 2010 at 6:03 AM · edited Fri, 20 December 2024 at 6:51 PM
I have one problem where I render videos from Poser. I see the picture with this radio
Estruch ( ) posted Tue, 07 December 2010 at 6:05 AM
Where I created the video changed the radio of image.
I understand nothing. Is not exist something system for not changed this radio.
Thanks
Estruch ( ) posted Tue, 07 December 2010 at 6:06 AM
Thanks
cspear ( ) posted Tue, 07 December 2010 at 7:12 AM
Radio?
Do you mean RATIO?
PoserPro 11 - Units: Metres
Adobe CC 2017
3Dave ( ) posted Tue, 07 December 2010 at 7:21 AM
On the main menu bar, Render tab, set Render Dimensions to the same size as your chosen video dimensions. Then in the Window tab, set window dimensions the same size if it will fit your screen or choose Production Aspect, then your workspace image will have darker views of what is outside the camera view.
Estruch ( ) posted Tue, 07 December 2010 at 7:29 AM · edited Tue, 07 December 2010 at 7:31 AM
Quote - Radio?
Do you mean RATIO?
Yes, ratio.... I'm sorry
Thanks for your help
seachnasaigh ( ) posted Tue, 07 December 2010 at 8:00 AM · edited Tue, 07 December 2010 at 8:02 AM
The aspect ratio (height:width) looks about the same.  The change seems to be that the camera has been pulled back.  Check to see if there is a keyframe for the Ztrans value of that camera, or if the focal length has been changed.
