gabe, i think it's just fantastic! i don't go much to galeries, so i'm glad that you posted it here again. those shadows on her left arm are just great. couple of things only: - that shadow on her back is coming from an unlogical light source. imho, it would be better if the light came from the water, leaving some caustic reflexions on her right arm. see that tree on the right - it gets it's light from under the horizon - from the water. maybe you should keep that left hand light source, but make it weaker and with very small shadow map, like 30-50, just to get some very difuse shadow. - the hair strands are bit too uniform (but you can fix it in the post production). please post it again when you finish it.
Ok first, the hair do you meen the strands on the left right or boath? I asume you meen the right, couse when I looked at it again it relly din't look right to me, but I hate to do post wirk so I'll play with it in Max. As for the light scorce, that is a good point too, I never thought of that, but the tree she is leaning on is also a 3D model. I Went and took a shot of where she was leaning the next afternoon before we left, and couldn't quite get the angel right so I moved in alitle and swiched to a wider lenze. The tree she is leaning on was made in Max with my own textures and alot of Headachs. The back and the tree are acualy the same light, but maby if I change it to a directional... I will see how I can work on it. I really just want to render it in max, but am having so many problems with the reatrace engin and Win2K that I can't... Thanks!!! I'll repost when work on your recomendations. -Gabe-
Gabe, I like the atmosphere and the thought. The elbow that she is leaning on looks almost like 2 elbows with that lighting, and there is no cast shadow on the bark of the tree, so it doesn't look like it is touching. Her fingers might be darker, too, less distracting. The orange lens flare in the tree just to the left of her head is distracting, also. The horizon line is not level. Added to the line of the tie across her back, it is a bit unsettling. I'd fix the horizon first of all, since you want this to be a peaceful image, then touch up anything else which distracts from it. Carolly
