Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
There should be a file list included with the DAZ installer. When you install the item, the ReadMe will give you a list of things and (usually) where to find them.
In any event, do you mean the template? It's very rare for an actual texture to be in BMP format. If it's the template, that should also be available from the installer file, or from the product page at DAZ. Or, you can create your own by loading the MFD into UVMapper.
Quote - Poser 7
OK, that is good to know...
You can find the name of the file it is expecting by clicking "Image Source" area of node and going into "Texture Manager". If you click on name while in texture manager is will give full specification (i.e.,name & location expected).
But as before, the basic dress is untextured. It sounds like you have applied a MAT pose or Material Collection that is not part of basic MFD.
Can I second the plea for a screenshot? It's nigh impossible to help you if we're not on the same page. I'd also like to see that "caution sign" - I've never ever seen that in Poser...
If it says "none" in the texture channel, then there's (duh) no texture applied. There's still the bump map (noise node) though.
Quote - I'd also like to see that "caution sign" - I've never ever seen that in Poser...
The caution sign comes up in the material room's simple interface, if the material has features which can't be displayed in that mode (i.e. anything more complex than a Poser 4 style set-up). If you never use the simple mode you won't see it.
anyone know the file name of the texture bmp used for the V4 MFD please?
been trying to find it. since it isnt used in all the areas for the dress. and I need it for the parts that do not have that texture.
thanks
